Question about GoVideo VR2940 DVD Recorder/VCR
Vcr jam There is a tape stuck in the vcr portion of the player. when pressing the power button the vcr runs for about 5-10 seconds. After that there is an error message on the screen. How do I fix this?
    President:
  • 3,130 Answers
You really should take this unit into a repair shop with the stuck tape as to get this bugger out of the unit will require the tape loading mechanism to be disassembled. if this is not taken apart correctly, you could cause more damage to the unit. Good Luck.
Posted on Apr 08, 2007
My vcr and dvd combo is turning on for 8 seconds after i press the button and then shuts off. What do i do?
When a VCR encounters a mechanical problem, such as something wrong with the mechanism or a tape that gets stuck, the electronics will detect this and shut off the power to prevent further damage.
The mechanism will need to be checked to see what is wrong with it.
Jul 14, 2016 | Televison & Video
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Jun 21, 2014 | Panasonic Televison & Video
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Tape stuck in vcr. when you press the eject button vcr starts to work but shtuts off the power Model number DVR-3034N. I have only taken the front and back covers off. Turned slanted roller untill the...
It sounds like the tape is jammed in the vcr, remove the top cover of the machine this will expose the tape. If the tape is spewed in the mechanical section and around the video head, get a pair of scissors and start cutting the tape and carefully remove all tape particles, when all tape debris has been removed, plug in vcr turn on and eject. If the tape looks good, you may have a loading basket problem, bad idler ***. or broken drive belt. "Lets hope for the best"
Jan 25, 2011 | Emerson Televison & Video
Stuck tape
If I remember correctly, press and hold the power button for ten seconds or a little more. If its not the power button try any button but I am pretty sure you will not be discouraged.
Sep 18, 2008 | Proscan PSVR74 VHS VCR
Emerson TV won't stay on
I am currently have the same problem . I just got off the phone with the support tech and he suggested unplugging TV for about 5 minutes and if that doesnt work to unplug TV for about 2 hours. He said that may reset the TV . I am waiting now. If it works , I will leave feedback.
Nov 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
DVD door will not open
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
SAFE
Hold down the power button (or the vcr button if on a combination remote) for six seconds. This will unlock the child lock feature of the vcr.
Aug 12, 2007 | GE VG4060 VCR
GoVideo VR2940 DVD Recorder/VCR Logo
88 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
