Question about Dryers
Kenmore 80 series quit heating after burning smell..
Our dryer seemed to be broken for a couple years. We got a new used one. Then IT stopped working. We pulled our old one back out [kenmore 80 series electric]. The door switch had gone bad, we replaced it and it worked again. YAY!The first load I did, I noticed a strong burning [like wires burning up] smell. My husband said ''it should be nothing''. Well, the heat WAS working until after the the burning smell, when the load stopped, I check them and they were a little warm but still wet. After I restarted it I noticed no heat was being produced. It is set on heat dry and timed so heat should be there. Please help. I'm tired of my laundry taking 3 days to dry!
  • Raven Horn Dec 27, 2008
    The exact piece you said fixed our problem! Thank you so very much for your advice. It was fairly easy to install & inexpensive too. Just glad our dryer is finally working properly. High five!
  • Dryers Master
  • 8,220 Answers
Any kind of lint or cobwebs on the element would cause a hot spot and fry the element or pop the limit that is mounted on top of the chamber. What your hubby soulda done is take the machine down and vacuum it out after sitting up so long. The fuse is not blown because it still runs so it must be the small guy pictured. It mount up top of the heat element chamber.Kenmore 80 series quit heating after burning smell - ff8b5e7.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 22, 2008
My kenmore series 80 makes a lot of noise and has a burning smell
They could be. Is the smell electrical or rubber.
Feb 03, 2013 | Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore 80 series stop turning
most likely a bad motor; expensive.
May 19, 2008 | Kenmore 63942 Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
575 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
