Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
My washing machine stops all the time and beeps with the F 11 flashing. I have tried unplugging the machine so it can reset itself but that doesn't work. I am ready to throw it away! It seems to have trouble going into cycles.
    Problem Solver:
Sometimes the unplugging helps, or hitting "Cancel" several times.  Guaranteed to work though is to remove top, reach down the top to the door lock.  (Tight squeeze and need to be a little tall to reach) Once your hand is down there, on bottom of lock mechanism is a small handle that must be pulled straight down and manually unlock the door.  This can also be accomplished by removing lower front panel and reaching up to do the same.   BTW, while in the top, make sure all the electrical connections are tight.  I found some loose before, probably from the spinning action.
Posted on Jan 04, 2009
My washing machine fisher paykel mw511 stopped working and now only beeps and show red light on spin. But don't spin or wash clothes
Is this the same company that makes Fisher-Price Toys?
I thought so, well you get what you pay for! OK most machines have some Reset function process. Most work by unplugging the machine for 5-10 minutes (computer to reset) then plug it back in. You should get a prompt/ audio or text message (if there is a window) that alerts you that the machine is resetting itself. Then just follow by testing a Light load setting so you do not have to wait around a long time. IF...This does NOT work. THEN...My Friend...You have a BAD control board. Which is like a computer board. And those are EXPENSIVE! $200-$400. So then it becomes economics. How old is the machine 5+ yrs? Buy another Machine
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Mar 15, 2014 | Washing Machines
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
How to reset or unlocked the beko washing machine timer
My washing machine time delay switch is flashing and I can't turn the machine on what do I need to do?
Feb 07, 2012 | Beko Washing Machines
My Fisher Paykel washer fills (doesn't matter if it is hot, warm, or cold) in short spurts/bursts starting and stopping, then bursting water in again for a few minutes. However, after about 5 minutes...
Sounds like a rotor position sensor fault. This part is fitted to the motor itself and is a little green circuit board in a white plastic holder. To get it off, first unplug machine from wall then lean machine back so you can get underneath it. You will now see a large round plastic cap 16mm socket to remove that and then 10mm socket to remove the 4 bolts on the motor. Once motor is off you will see the sensor, be careful when removing it as not to damage the wire on the motor itself. You should see a little arrow on the motor where it comes off that is a marker for the long centre stalk of the sensor holder and motor wiring is also marked on the motor itself Y B R for when you put it back together.
Sep 24, 2011 | Fisher and Paykel Fisher & Paykel Washer
FIsher and Paykel washing machine won't stop beeping.
if you remove the back panel you can look under there, there should be atrouble shooter/techsheet that will let you know what the flashinglights mean. if not theres a tech support number to aid you as well
Mar 02, 2009 | Fisher Washing Machines
Flashing stop light
have you tryed unplugging it for 5 minutes to see if it resets itself?let me know-mike
Oct 31, 2008 | Hoover Washing Machines
F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
Sep 15, 2008 | Washing Machines
Flashing F and alarm
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.... Hope this helps
Jun 08, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
61 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
