Question about Samsung TCC1340 13" TV
Help with the Chroma Switch
I have a Samsung 13" TCC1340 tv. I ca nrun it for a day and then the next day it will not run. i have to open it up and flip the CHROMA switch back and forth and then it will power up.
  • Anonymous Mar 25, 2014
    The Chroma 6314 mainframe unit fails to initialize (it freezes) when turned on
    Genius:
  • 1,074 Answers
Have a tech look on your tv to repair it, you could be having a intermittent problem in the power supply and related circuits.good luck
Posted on Apr 08, 2007
Please help me, i'm repairing 14" old model television.. it don't have brand name but it is using 47C434N-R201 system, TA8680N video chroma IC, 30115 regulator, my problem is it don't have...
Good day!
Try to check the base of the horizontal output if have a signal from the chroma or jungle i.c it should have 5-7vac to trigger the high voltage.If no voltage try to hang it and check again if the voltage appear while you hang it,your ply-back got partially defects replace it with the same type and ratings.
Next,if you already hang the base of h-out and still no voltage on it and the chroma i.c is new.Trace the line from the base of h-out to the chroma/jungle i.c.Test the parts that pass through that line such as open/change value resistors.
I hope this solution will be helpful.Thank you I'm very glad to share my idea.Good luck.
Apr 21, 2011 | Mitsubishi Televison & Video
Our Samsung slim fit t.v. is displaying a completely RED picture. Any trouble shooting tips?
if the problem is always red picture every time you open your TV unit i may say that there is problem in your CRT chassis board or at chroma driver. open your unit then pull out the chassis board clean with lacquer thinner and then check possible loose contact re soldered parts at color amplifier section and parts at chroma board which is the driver of red, green, and blue gun. it is connected at the neck of picture tube. after you try all this option test your unit then observed if it is ok now. if still doesn't change red picture again check defective parts at chroma board pull out the driver transistor of green drive since the problem is reddish so there is no green drive check if it is leak or shorted also check open resistor. also you need to consider is the voltage of all the driver transistor are almost the same to have good picture.
Apr 09, 2011 | Televison & Video
I have no color on my Samsung Flatscreen TV
This means absolutely no color - equivalent to a black and white picture. Not even a hint of color.
First, confirm that the source is actually in color - try another channel or input device.
Next, check the settings of the color control - it may have accidentally been turned down. If your TV has some kind of automatic picture mode, try turning if off and adjusting the color control. Try adjusting fine tuning if you have such a control and the problem is with a broadcast or cable transmission.
At this point with a confirmed color signal source, there is a problem with the chroma circuitry.
Note that to the average person, the obvious question becomes: is my color picture tube bad? The answer is a definitive NO. It is virtually impossible for a defective CRT to cause a total loss of color. A defective CRT can cause a lack of a primary color - R, G, or, B or a short between two colors which will mess up the color but is not likely to result in a black and white picture.
Some possibilities in no particular order:
Weak signal or defect in tuner/IF causing loss of signal strength.
Coler killer set too high (internal control) if it has one.
Defective part around the chroma chip/circuit. Faulty color oscillator.
Bad connections in area of chroma chip/circuit.
Defective chroma chip (don't suspect this first just because it is probably very expensive).
Try prodding the main board around the chroma chip with an insulated tool to see if you can make the color come and go.
I had one set where a $.02 resistor decided to open up causing just this problem - perfect BW picture, no color. Another had a coil with a broken wire.
Jun 14, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Red light flashing on tv and tv won't switch on
sound like chroma ic problem. but you not present model# so i can"t tell you what correct# for it. if you know about what is chroma ic, replace it. if not take it to prof shop do it. good luck!
Jan 05, 2010 | Samsung TXM3297HF 32" TV
Samsung HL-S5087W shuts off.
the number is 3409-000178
should cost less then $5
Dec 29, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung LE26R7 TV not coming on
Check for main fuse open 4amps. Maybe pwr supply is going. Other possible thing Horizontal transistor ( short) stop run B+. Thank you
Jul 27, 2008 | RCA P52926 52" Rear Projection Television
COLOR PROBLEM
your tv need a reheat.reheat from video chroma to crt board
Oct 16, 2007 | JVC AV-27530 27" TV
Was distorted picture, now no picture
ok,try to resolder or reheat the main board of your tv.from microprocessor,the video chroma section,the crt board...if reheating is not the solution,replace either the microprocessor or the chroma or crt driver.
Oct 10, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Color is gone in a sony kv-c2963e trinitron tv
as you say that color came back for 15 minutes then went off. this is a clear indication that there is a loose contact or pcb crack somewhere in color section only. if that happens to be ok then check 1 antena or cable socket loose 2 loose connector in color section 3 print open or crack near chroma signal processor. 4 loose near color control. 5 chroma ic night be defective. if you are not tech person take the help of tech.person.
Oct 01, 2007 | Televison & Video
Tv turns on, but when you turn it off it won't turn back on.
sounds like its a cold solder connection somewhere in the set or a capacitor thats bad in the power suppy.. These problems are the most dificult to troubleshoot unless they happen all the time.sorry I wish I could give you more info..
Mar 26, 2006 | Samsung TCC1340 13" TV
Televison & Video Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
