Question about Kicker CompVR 05CVR84 Car Subwoofer
BEFORE I START IT THIS SUPPORT FOR THE AUDIO SUB SUPPORT OR NOT
  • 15,935 Answers
Yes
Posted on Dec 24, 2008
What color is the wire for the subwoofer on the Kenwood KDC-400U
The sub-woofer isn't connected to the wiring harness of the KDC-400U. It has to be wired separately. Then the sub-woofer input gets connected to the KDC-400U sub-woofer out using R/L audio wires as show on page 13 of the Quick Start Guide. The direct link to the Quick Start Guide is http://manual.kenwood.com/files/4fd9a24acb9fa.pdf . You may be able to use the wiring information on pages 12-13 to help you determine which wires aren't going to the sub-woofer.
Most Kenwood Car audio manuals are available here: http://manual.kenwood.com/en_contents/search/ .
I wish that I could give you more information.
Apr 28, 2017 | Kenwood Car Audio & Video
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
How can i make this sub be a single line in and not use any of the speaker outs on it?
Ron just what are trying to do? VGA is Video Graphics not related to Audio. SUB...meaning Subwoofer I assume?
State the facts as to what you want to accomplish from start to finish. Let us know what Hardware you are working with and the type of speaker/s you are attaching.
Dec 23, 2013 | Audio Players & Recorders
My MTX Jack Hammer JH300 Amplifier is warming up... A red led indicates that the amplifier is warming up.I checked the conections and everything seems to be ok, I've a 10" Jack Hammer JH 4510 Sub...
Check the speaker connections from the amp to the box and inside the box to the sub. Its possible these came loose from vibration. Also gently push in on the sub. It should move freely and feel spongy. If it drags or is stiff the sub may be bad. Use an Ohm meter and test the sub. There is an Ohm rating on the sub (usually 4) and it should be close to that. Also check the audio in. Maybe the amp/sub combo is fine but there is no sound going in. Use an MP3 player with a 3.5MM to 2M RCA cable as an input. Start with the volume all the way down and SLOWLY raise the MP3 volume.
Please Rate!
Apr 28, 2011 | MTX JackHammer JH300 Car Audio Amplifier
I have a sony str de 325 receiver....what sub woofer will go with it and where do you plug it into the receiver?? Thanks
You will need a powered sub, one that has a built in amp. It will also need speaker terminal type inputs. Use the B channel to send signal to the woofer. Since the audio from the B channel is full range, use the crossover on the sub to determine which frequencies you want to hear. I would start at 100Hz and go up and down from there. Use the gain to adjust the volume in relation to the other speakers. The sub volume will be affected by the master volume.
Please rate if this helpful
Apr 05, 2011 | Sony STR-DE325 Receiver
I have the Subwoofer plugged into the output and have it turned ON but it's still not working!
It only drives a self-powerd sub.
The manual...
http://www.retrevo.com/support/JVC-RX-8010VBKC-Receivers-manual/id/315dj079/t/2/
Page 17:
Setting the Subwoofer Information
Register whether you have connected a subwoofer or not.
Before you start, remember....
• There is a time limit in doing the following steps. If the setting is canceled before you finish, start from step 1 again.
On the front panel ONLY:
1. Press SETTING repeatedly until "SUBWOOFER" appears on the display.
The display changes to show the current setting.
2. Press CONTROL UP / DOWN to select "YES" or "NO."
• Each time you press the button, the display alternates between "YES" and "NO."
YES: Select this when a subwoofer is connected.
NO: Select this when no subwoofer is used.
Note:
You cannot use SUBWOOFER OUT ON/OFF on the front panel (see page 14) and adjust the subwoofer output level (see below) when "SUBWOOFER" is set to "NO."
Then continue with setting its relative level and other things.
Feb 06, 2011 | JVC RX-8010V Receiver
POWER ISSUES
Recomend installing a capacitor, this will control voltage drop and reduce heat. The new battery should help, but it also may be that the amps final circuts could be wearing out, and no longer able to handle the load of the sub.
Sep 28, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Mid level volume my sub starts poppin
Set your gains correctly. You are overdriving the sub, causing the voice coil to bottom out. Go to www.jlaudio.com and go to the support / tutorials section and it will have a tutorial in there that will tell you how to properly set your gains. The same information is also in the owners manual that should have come with your w7, and probably also says how in your amplifier owners manual.
May 31, 2009 | Jl Audio 1000/1 Car Audio Amplifier
I did what you suggested..
Take it to a car audio shop that has test bench and ask them to check it for you.
May 07, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Sub
Most amplified sub woofers need to be grounded to the output source.If you plug the sub woofer in to the receiver you would use a ground wire from the receiver to the sub woofer there should be a ground terminal on the sub woofer and receiver.
Feb 17, 2008 | JVC RX-778V
Kicker CompVR 05CVR84 Car Subwoofer Logo
29 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
