Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
My Hoover steam vac is not spraying the water. Instead it is ejecting 5 streams. This is a new probolem and in the several years I have used it I haven't had this problem before. I can find nothing in the manual that explains it or "fixes" it;
There is a filter screen under the plastic cover below the brush indicator. If it is dirty clean it. The solution pump works off of vacuum. If this screen is dirty then the pump does not work correctly. Funny, the manual says nothing about this, only that the plugged screen can affect brush operation. I had the same problem with my solution and as soon as I cleaned the screen ......vola, the solution dispenses great again!
Posted on Sep 08, 2010
  • 2pines Apr 16, 2011
    I had the same problem - water coming out in streams rather than an even spray. Works perfectly now after cleaning off the little screen filter. (Pop off the plastic cover under the rotating brush speed selector.) Thank you for the fix!
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
Jan 17, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steamvac won't spray water/cleaning solution
Clogging of the pump that sprays water/cleaning solution is very common in Hoover and Bissell Steam Vacs. Try running a cycle of 1part vinegar or CLR to 3 parts warm, distilled water through the vacuum pumps. The heads get clogged with soap and the water pumps get clogged at the opening of the flash heater due to minerals in hard water. If you want to extend the life of your steam vac, don't use the heater unless you are using distilled water. This can get expensive, so I recommend not using the heater.
Sep 11, 2009 | Hoover F7431-900 SteamVac Vacuum
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
We purchased a Hoover Steam/Vac (F5915-900) cleaner. We assumed it be a combination STEAM and Vacuum machine. Where is the Steam? I will await your reply. Thank You.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761645
Generic problem for all Vacuums
Posted by hjopmi on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I have a similar Hoover “SteamVac” and the vacuum does not create steam as you stated, but you do have to use the hottest water with cleaning solution and the Hoover will clean your carpet by spraying down the solution, the scrubbing brushes will loosen the dirt and the vacuum will pickup the excess water until the holding tank is full and then you have to empty it, and then start again. The word “Steam Vac” is something that the Hoover factory labeled but so far I have not seen anything that actual produces “Steam” while cleaning. Feel free to contact the Hoover factory with your complaint @ the information listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Steamvac
You might try running a solution of vinegar and water thru it to clean out the lines and spray nozzles. Also are the brushes turning when you are using it, that could also be the problem.
Mar 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
425 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
