I have a Newpad M78 MID Android Tablet. It's switching on but will not finish loading & gets stuck on the "ANDROID" animation screen forever.
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
SOURCE: I can't use the touchscreen on my mid tablet, how can I reset it?
Try turning it completely off for about a minute then turn it on again.
SOURCE: Changing Language on MID Android Tablet
Try this YouTube video, it shows how to change from Chinese to English and you can see from the menu layout which menu items to press.
Click here
Gadget
SOURCE: coby kyros mid 7022 is stuck on lock scteen, how
Here is the instruction on how to do the factory data reset when a customer locks the system and lost his security password/pattern. This instruction works for MID7016 and MID7022. An end user must follow each step precisely. Otherwise, he/she will not access to the system menu mode.
Give the reboot at least 5 minutes. Do not assume the unit has frozen
SOURCE: my android system isn't boot on the tablet
if youve tried everything then yoou should contact the manufacture or costumer service for that product and ask forr assistence
