Question about Dayton Gas Furnace Heater
Won't go past 68...
I have a dayton gas furnace that when you set the heater temp past 69 it will heat it's self up to 68 and then just start blowing air. It won't pause or anything it just keeps blowing. It's freaking cold outside and I'm tired of getting up and resetting it every 3 min. Especially at night we wake up in the middle of the night and the in house temp is around 59, desired temp is set at 69-70 and it's just blowing air.
Be sure the filter is new and clean
Check Chimney/vent to be sure it is not plugged or iced up.
Also if it has a drain be sure it is not kinked or plugged and draining correctly
Posted on Dec 22, 2008
Heating furnace blower won't stop
Check out the afc could be dirty remove and clean back of it , or replace afc , also check fan on fan off settings on afc
Jan 10, 2013 | Dayton Gas Furnace Heater
Model 6k890 motor
Will the fan run with the fan switch in the ON position? as opposed to the AUTO position. If so the temperature or time delay or motor may be bad.
the fan switch operates the fan relay that controls high/cooling speed, heat speed is a time or temp delay.
Oct 25, 2012 | Dayton Gas Furnace Heater
Dayton gas furnace model 3e385 works and lights but as soon as fan comes on the unit shuts off and lights again wondering what was wrong
Check heat exchanger for cracks or holes which will cause the fan to blow out the flames. The flame sensor on the pilot or burners has to be in constant contact with flame to operate normally. If the flame is put out by a cracked exchanger the exchanger or furnace needs to be replaced.
Nov 22, 2011 | Dayton Gas Furnace Heater
Furnace will kick on, begin heat up, go to the point where the fan should start and the whole thing shut down. If I move the thermostat down below the temp it show, it will start again and do the same...
Sounds like the blower motor is bad and then the unit is kicking off on high limit....
Probably nothing you can do with out getting a new motor to replace the bad one...
heatman101
Feb 02, 2011 | Dayton Gas Furnace Heater
I have a Dayton Furnace Serial# swglm033942 and need some information; My furnace is installed in the attic and sometimes it will not blow hot air. I have tried to start it and the burners start up, but...
Please have this checked out by a technician. If there is a crack in the heat exchanger it could do just as you described. The blower blows air into the combustion chamber and blows out the burners.
Jan 07, 2011 | Dayton Gas Furnace Heater
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
I have a honeywell ct3200 with a trane xl 80 furnace. it will cycle on to the right temp, go off and cycle the furnace back on 30 seconds later. Is that normal? It is 32 degrees outside, set at 68
Hi, check page 22 in your manual, it says "Adjust the screws on the back of the thermostat as instructed on page 7." Your furnace is a 80% efficiency but is also a high efficiency 2 stage heating system so try adjusting screws A and B both ways and see which gives you the correct cycling.
Your manual is here:
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0653.pdf
Jan 18, 2010 | Honeywell Programmable Thermostat Heater
Fan continues to run after heating
That's the fan switch. It's a thermostat that controls the fan coming on and off, it's probably failed and needs to be replaced. You can see it if you take the front off the furnace, the wires come off it and go to the fan motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 13, 2009 | Dayton Gas Furnace Heater
Dayton Gas Furnace Heater Logo
154 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Tim Whalen
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
