Rear defroster light is coming on but not rear defroster is not working and there is a wire that has come loose and that is just hanging there when I open my trunk! It's a thick, round, black wire that has three little prongs in the the middle of it and it kind of looks like a cable wire that you would run to your TV to get cable and the 3 little prongs looks like what you would plug into the back of your TV. Could this be it or what kind of wire is this?
SOURCE: 1996 Honda Accord Problem
I cannot get my air conditioner clutch on my 1996 Honda Accord EX to engage. I've checked the fuse and relay. The fuse is good but the power is not going to the relay. If I can find the power that comes to the relay, I can fix it. I need to know what activitate the relay and the power that the relay push to the clutch. I need to know where they come from.
I've been looking for a circuitry that shows it and a drawing that shows the air conditioning fan. Please help.
SOURCE: 95 honda accord V6 tachometer jumping and cutting out.
I had the same problem with my 1995 Honda Accord V6 2.7L a year ago. It was a pain to have Honda diagnose the problem because it was intermittent and every time I took my car in to the dealership they said they couldn't reproduce the problem, but the longer you wait the more frequently your tachometer will fluctuate. I finally stopped by the dealership when the tachometer was jumping and they were able to diagnose the problem. In my case there was a faulty resistor in the ignition coil, but the entire ignition coil needs to be replaced. I don't know anything about cars but I know this fixed my problem. I went directly though Honda's service center so I know they charged me more than an independent repair shop but I'm looking at my invoice now and I paid $150 for the ignition coil and $200 for labor. After Honda diagnosed the problem I searched for "1995 honda accord ignition coil tachometer" and found that other people had the same problem and replacing the ignition coil was the fix. Hope this helps.
SOURCE: 1993 Honda Accord No Heat/Defrost
You will have to drain the radiator. Drain at bottom.
Then, follow the top radiator hose back to where it connects to the engine.
The part with the two bolts in it that the hose connects to is the thermostat housing.
You may have to remove the hose in order to remove the housing.
When you have removed the housing, note the position of the thermostat before you remove it.
When installing, use new gasket, etc.
(you might be able to get away with not removing the radiator hose, but it is recommended)
Be prepared for a bit of spillage when you remove the housing.
SOURCE: trunk/gas tank latch wont work (honda accord)
I have this problem now i got my trunk to lock by going in the trunk and removing the wire from the hook that was keeping it loose. Now i can lock my trunk but i am still looking for a way to get in my gas tank. Help me please if you can.
