Question about GE 25865 Cordless Phone
GE 25865, and GE 25866 Changes the time
I have a GE 25865 base unit with 3 GE25866 remote units in my home. The problem is they all seem to change the time by 3 hours and I can't seem to get it to stay on my local time. I have made sure all units are on the correct time, date, year, area code and the next day all are 3 hours earlier. Any suggestions would be greatly appreciated.
Thanks, Lee
  • 201 Answers
SOURCE: Ge cordless 900 mhz home phone
What is "Bell" and "Cogeco"? Did you change phone line provider companies? If so, you would need to ask them if it's possible to change. You are getting the information they are sending you. I do not believe the information is being altered by your phone.
Posted on Jul 07, 2007
SOURCE: GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Posted on Feb 19, 2009
  • 272 Answers
SOURCE: Unable to talk on two handsets at same time when receiving a call
Unfortunately that is the untold story about cordless phones they only have the capability of 1 open line be it the handset or or the base. There are some very pricey multi line systems, I have the same system bought two extra handsets and found out too late that I can only use them one at a time! Sorry probably not the answer you were looking for but thats the reality...
Posted on May 22, 2009
Please note that if you have a wireless router for you computer in you house, it will definitly interfier with the 27911's registration process. Make sure you shut you wireless router first, before you try to register to the base (27909) unit. That worked for me.
Posted on Jul 12, 2009
  • 3 Answers
SOURCE: for ge 25942ee4 5.8 ghz - i can't locate
1. Make sure the answering system is ON.
2. Press fash/answerer/call waiting button on the handset to enter answerer remote
mode.
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confrm the setting.
Posted on Oct 06, 2009
Batteries seem fine.
Hi Paul,
Base on your questions, I'm assuming that you are trying to sync your universal remote control to your GE 13GP344. If so, you may try the codes below.
GE Universal codes
000/ 003/ 004/ 009/ 022/ 031/ 044/ 052/ 054/ 055/ 087/ 092/ 103/ 107/ 125/ 164/ 181
Enter 3 digit code at a time.
Note : Codes vary on the brand and model no. of the universal remote control. Codes above are the most common 3 digit used for GE television, however if the codes didn't resolve the issue, you should give me the brand and model of it to determine the exact codes for your unit.
You may also confirm if your remote control is working fine by aiming directly the infrared emitter (sensor) to your cellphone camera, while pressing any button key on the remote control, you will be able to see the flash of the infrared coming from the sensor. Please watch this video for more info on how to do this.
Please let me know if you need further assistance.
Nov 11, 2011 | GE 13GP344 13" TV
The main unit will not connect with the remote. I have tryed everything that the manual has said to do.. But it just won't work.. They seem to be working but not comunicating with each other..
The WS20 has very poor engineering.
1. Open battery compartments of all remotes and the base unit.
2. The following steps must be completed within a small time window of a minute or two.
3. Remove and replace one battery from the base (reset button on base may also work)
4. Remove and replace one battery on first remote.
5. You have 10 seconds to set the channel number, suggest you set channel 2 first if you have 2 remotes. Once you stop setting the channel on the remote, 10 seconds later remote 2 should sync with the base.
6. Remove and replace one battery on second remote.
7. You have 10 seconds to set the channel number, if you have only two remotes do nothing and it should synchronize 10 seconds after you replaced the battery as remote number 1.
8. If the base unit can receive the time signal from Colorado USA, it should eventually get the time and date correct, give it time. Alternatively you can set the time and date manually. However, if the base is trying to get the time signal, most of the controls freeze up, to unfreeze them press and hold the + button for something like 5 to 10 seconds, then the unit should be available for manual setup.
If you loose connection to one remote or change batteries, repeat all of the above.
In summary, it a POS unit .... :)
Dec 27, 2010 | Alert Works Enhance Living Series WS20...
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
The remote no longer changes stations but some other functions still work . The receiver has essentially never been touched as I always use the remote. The tuning functions do work manually but some do not...
I found a wonderful vendor on eBay that was selling the remote for my unit. At no charge, he offered detailed step by step instructions how to reset and test the remote. Although it seemed strange at the time and involved a digital camera, I did what was suggested and the remote in now working fine.
Jul 22, 2009 | Sony HT-DDW670 System
SA-PT750 rear wireless speakers don't work
Just solved this one thanks to another posting on this site.
Turn all components off.
Check to make sure your wireless card is snugly plugged into the back of the home theatre unit. (Of course you already have. Check again, though, while everything is off.)
Turn wireless unit on first.
Turn on home theatre unit.
The W1 light should be on and blinking red at you (darnit!)
Here's the magic.
Hit the >>/>> button on the front of the home theatre unit WHILE you hit the number 3 on your Panasonic remote.
The screen changes to a P
Then, the wireless unit light should change from red to green (HOORRAAYYYYY!)
If you have multiple wireless units, at this point, you should also hit the Set/ID button on the back of the wireless unit (it is the kind of button that requires something to poke into it to set it).
Then simply hit the >>/>> and 3 at the same time again.
All's good.
And by the way, shame on Panasonic. not only do they not seem to carry these manuals anymore (how hard would it be to have a PDF file and a link on a web page?) but the support info they did have did not contain these steps. Thanks to the FixYa member willray411 for posting this first!
Mar 29, 2009 | Panasonic Audio Players & Recorders
Uv9 codes????
1)turn on the unit with no disc inside2) Go to Set up.
3) Select Preference(press on the remote control , right button 3 times)
4)enter 9 6 5 3 on the remote control.
5)Screen changes,includes region code, Use Arrow keys to change .number to either 0 or your area code.
Thats all'
However once power is turned off it doesn't save changes and has to be reset each time.
Nov 10, 2008 | Televison & Video
My GE instajack is not working. It had a greeen signal, now it has a red signal.
Most likely, the extension unit cannot communicate with the
indicator light is solid base unit for one of the following reasons:
red • Base unit has yet to be installed. Install base unit. (Refer to
the Set Up section.)
• Extension is too far from the base unit. Relocate either the
base or extension unit to another electrical outlet. If
indicator light on extension
unit remains solid red, reprogram the link code on extension
unit
Follow these steps:
• Press and hold the button on the right side of the base
unit until the indicator light changes to solid red.
(Approximately five seconds.)
• Release the button, then the indicator light will blink orange.
This creates a new link code and places the base unit into
program mode.
• Follow steps (2) and (3) in the Additional Extension Units
section for all extension units.
• Press and release the button on the base unit to take it out of
program mode. The indicator light will change from flashing
orange to solid green.
Oct 10, 2008 | Computers & Internet
GE Simon Security System - help!!
The default for option 10 is 30 seconds and option 11 is 60 seconds.
It sounds like option 10 is turned off because when turned off the entry delay is set to 005 seconds. All entries must be 3 digits.
You ca set option 10 and 11 from 005-254 seconds. Hope this helps
Aug 12, 2008 | GE Security Simon 3 Wireless Home Security...
Cordless phone remote unit
The CL light flashes all the time and it wont let me program it>
Mar 18, 2008 | GE 25942GE2 Cordless Phone System
GE 25865 Cordless Phone Logo
67 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
