Question about Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32" LCD HDTV - Picture "jumps"
I purchased this TV on Black Friday of this year. This weekend the screen started to "jump" from side to side about 1/4 of an inch. It really bothers the eyes. It doesn't flicker but it looks like it's jumping around in small intervals. Kind of like a mini-seizure for my tv screen - no lights out but the movement is there.
I called the Cable company and they say all is okay. I called Geek Squad and they can't send someone out until next week!!!
Please, this is highly annoying and I am not a technical person at all.
Can someone help???
  • 8 Answers
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Posted on Aug 21, 2008
vortash
  • 431 Answers
SOURCE: Fuzzy pic on Dynex 32 LCD TV
I am sumising that you have checked the menu controls on your tv and are recieving your signal from the cable box , so therefore if it is not comong from the Aerial and direct from the cable company then the picture should be clear .. However sometimes people dont check to see if the signal is RGB or composite from the box RGB is usually best if you have a scart socket connection or SVHS if your set has that capability .. sometimes people have an old VHs recorder and the sinal is coming from that to the set through the Aerail fly lead if it is you will probably find they are conflicting giving you a poor picture retune your Video to another channel instructions should be in its manuel if not come back to me ... reagrds Vortash
Posted on May 01, 2009
aparsons89
  • 40 Answers
SOURCE: No picture on new Dynex 42" lcd hdtv
Do you have cable or DVD player connected yet? If not, connect your cable to the back of the LCD via Coaxial cable. Next turn channel to 3 or 4 whatever channel you use for cable. Then use auto programming to find all of your cable channels. If no cable connect the DVD outputs to one of the AV 1 or Av2 inputs on the back of your LCD. Power on the DVD player and change your input to which ever AV you connected it to. You should see a blue screen and your DVD Player Icon.
Posted on May 13, 2009
  • 27 Answers
SOURCE: dynex tv has green where is should be black in the picture
first check all componet wires in back make sure they are connected properly...if thats not it try reseting your color scheme thru your remote usually under the menu under picture or color and if thats not it it could be your bulb is going bad but try the first 2 things first
Posted on May 14, 2009
  • 814 Answers
SOURCE: I have comcast digital cable
Here is the webpage for the Dynex remote codes. I hope this helps you solve your problem. (www.dynexproducts.com/universalcontrolcodes.aspx) Copy the web address and paste into the address bar in you browser. That will take you to the page that has all the remote codes for Dynex televisions. You can use the webs site for customer support also with the customer support e-mail. They will be able to help you find the right code if you cannot find it on the code page. The Dynex customer support telephone number is 1-800-305-2204. you can contact them between the hours of 7am and 12am CST.
Posted on Jun 06, 2009
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32 in only shows black and white now
Black and White on a new setup would indicate you've plugged in AV or Component cables incorrectly. Match the colors up, be aware some Dynex models have AV connections on the SIDE of the TV. Don't just plug colors into random places. Failing that, check to see if your still inside 1 year manufacturer warranty or a best buy product protection plan. If not, seek out repair locally.
May 15, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex L26 10A purchased little less than year ago has audio, but black screen. When first turned on screen will display: "Please Wait", then screen goes black, but audio can be heard. Tried uplugging from...
Call for warrenty serviced,u still have warrenty inforced until a year.Ur tv have intermittently signal shutdown before it come throught the Tuner board not,carrying to the LCD Screen to produced a picture.
Jul 03, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Trying to change tv format on my dynex 32 LCD
You are looking for a picture size, format or screen size button on the remote control to solve the issue. If it connected to a HD cable or satellite box then they also have format or picture size settings.
Apr 13, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex tv no picture screen comes on and then goes black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 18, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
I have a 32'' Dynex TV and when I turn it on all I get is sound and no picture just black screen.
The problem can be the backlight inverter board is bad or it is not getting power from the main power supply. those are the two places to look for.
Nov 05, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Thin line of no picture across tv screen
this is a resistor gone on the board easily fixed
Jan 17, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Wide screen lcd simple question.
Hi pooing stone,
You may sometimes find that even with a television referred to as “widescreen,” widescreen movies still have letterboxing.
This is likely because the movie you are playing is still in the ratio used at a theater. While most televisions are 4:3 for the more square-type or 16:9 for widescreen, a theater screen is much wider still. Unless the movie has been reformatted specifically to 16:9 for your television, you will either see letterboxing or lose portions of the picture by zooming in.
If a movie is available in several ratios, I suggest thinking of all the options before buying. Although purchasing a movie reformatted to 16:9 will prevent the black bars, purchasing it without any reformatting of the size will prevent you losing part of the picture.
FYI: It is very common with Blu-Ray Discs that widescreen means original size, not 16:9.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 03, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Power button is green - no blinks / no picture / no sound
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
404 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
