Question about Tomtom One XL GPS Receiver
Floating in space even on interstate
As I'm driving down the interstate in NC (and other places), it seems to take me "off-road" and appears to be lost trying to find the road, but showing other roads not in the area. The screen appears that we are flying in space or driving through the brown area. There is a strong signal. Can't trust where it will take me. HELP!
  • paminpa21 Dec 23, 2008
    Thanks, I'll give that a try.
  • 78 Answers
As I always suggest, your maps might be off if you haven't updated since you bought the device, or haven't updated in quite some time. Run the device through TomTom Home to update your maps, and it should provide the fix
Posted on Dec 22, 2008
I have a 91 toyota 4Runner and when I'm drivibg
doesn't mean the transfer case isn't still trying too engage.even with the front drive shaft out.
Sep 04, 2017 | Cars & Trucks
Unit seems to be nose down position front wheel makes contact back and side wheels don't
With these pool cleaners, this is a common and easily corrected problem. Check the following things. First, make sure that the filter bag is not full. If it is, it could be weighing down the cleaner on one side. Next, remove the head float and shake it. If there is water in the float, you will need to replace it. This is most likely the cause of your problem. Finally, check the hose floats to make sure that they are evenly spaced and are not causing the cleaner to float improperly.
Jul 28, 2010 | Polaris 380 In Ground Pool Cleaner
Camcorder repair in Raleigh NC
hi there, you can try this place, call first to see if they can repair your camcorder:
Triangle X-Ray Company
4900 Thornton Road, Suite 117
Raleigh, NC 27616
Phone: 919-876-6156
Fax: 919-872-3986
Jun 26, 2010 | Sony Handycam DCR-SR40 Camcorder
I recently purchased a Garmin Nuvi 750 GPS. While
you can set the types of roads you want the unit to follow. Highways or otherwise.
Dec 27, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Describe your How can I set my garmin nuvi 350 to
If you have set it to fastest, as opposed to shortest, it should take you on interstates for the most part.
Oct 25, 2009 | Garmin Nuvi 350 Car GPS Receiver
2001 Ford Taurus rear end bounces/slips off to side slightly
This is most likly a low RR tire. Check the tire pressure first. If that is OK, I would slowly drive to somone qualified to examine the rear suspention to see what might have broken.
good luck
Feb 07, 2009 | 1991 Ford Taurus
Engine dies while driving down the interstate. battery gauge reads charged. it will not trun over. seems like the starter is not getting power
How do you re-start after this happens?
I suggest you carry a small volt meter, and check power and voltage at the battery and starter while the problem is happening. (I don't have to tell you that testing should be done well off the road where it's safe!!!)
Jan 03, 2009 | 2003 Chevrolet Suburban 1500
We were sent over the worse mountain roads going from Lexington SC to Franklin NC. It most certainly was a dangerous way to go on windy mountain roads. The NUVI indicated it was the fastest way and the...
Welcome to FixYa:
I am not sure which model of the Nuvi you are using but I have the Nuvi 660 and can feel your pain. What use is going over a mountain or down roads made of gravel and miles from civilization only because it is technically a "shorter route"
So here are the basic directions to change that setting and get the Nuvi to keep you on the highways and interstates. If it varies too much, either respond with your model number or go to Garmin.com and get the manual for your model:
Go to SETTINGS
then NAVIGATION
click on ROUTE PREFERENCES
You should find what you need here, but to tell the Nuvi which type of roads to avoid and which ones to stick to:
go back to the SETTINGS menu
touch NAVIGATION again
and click on AVOIDANCES
Hope this helps and be sure to keep us updated!
TJ
Dec 13, 2008 | Garmin GPS
Car started down shifting on its own, then wouldnt move once stopped, or roll even while trying to push.
Hello,Bharper,,
unfortunately it sounds like it's time for a new transmission.. sorry..
Sep 17, 2017 | 2003 Chrysler PT Cruiser
Tomtom One XL GPS Receiver Logo
63 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
