Question about Philips 27PT5445 27" TV
Problems with my screen/picture
Since a recent move, our Philips television has not been working the same. It did not get bumped around or anything of the sort. The picture is cutting off at the top of the screen. There is about an inch and a half blank and blurred space at the top. We have tried to adjust the width of the picture with our remote and it made no difference to the top of the screen. If anyone has any ideas or solutions, please let me know!! Thank you.
    President:
  • 3,130 Answers
Sounds like a vertical sweep problem in the vertical output circuit, or the drive circuit. this is a solid state set and there are no user replaceable parts inside. Please play it safe and take the set in for service. Good Luck
Posted on Apr 08, 2007
I bought this model from a friend and he mentioned that when moving the tv around it might get bumped a little bit and this could "throw the colors off". HE said i could pop the outter casing off...
Tv now have colors R,G,B lines mis alignments,have colors shadows or 3D pictures look alike?Yes,this tv have a problems known as a convergence problems,sorry but ur friend screw u over.This tv the convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.Fix the convergence board to solved the tv convergence picture problems.U have all the tools and can u do basic soldering?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.Or the shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
Philips 47-Inch 1080p LCD HDTV - model 47PFL3603D - worked great until we tried to move it - it was bumped very lightly, and the picture now only shows 1/2 the screen
There are two ribbon cables at the top centre of the display, if one is loose, you will only have half a screen. When taking a small bump the cable has become loose. Check the ribbon cables and connections.
Jan 11, 2011 | Philips 47PFL3603D LCD TV
My tv has thin black horizontal lines on screen while showing picture. this is not caused by cable since it happens while using ps2 or dvd player. I recently moved, but it was working fine after the...
that could be a sign of a bad panel. my experience is that these panels are more expensive than the tv itself, but might be worth looking into since I've heard about prices coming down
Mar 27, 2010 | Philips 42FD9954 42 in. Plasma HDTV
Componants in back don't seem to work, HD cable,
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2009 | Philips 55PW9363 55" Rear Projection...
The picture looks hazy and anything that is white has a certain glow to it
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 04, 2009 | Philips 51PW9363 51" Rear Projection...
Philips projection HDTV 51PP9200D/37. Convergence problem
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 13, 2009 | Philips 51PP9200D Television
Philips Magnavox 51MP392H Rear Projection Television
are you getting sound, was it moved laterly, did you just get it from somone, did it get wet, does it make clicking noises, was the picture color/ convergence blurring before this, were the colors slowly seperating such as red/blue/green?, did the picture bow on top and bottom or sides prior to tihs, was there anything note worthy prior to the blank screen.
generally its IC convergence problem with the larger philips projection TV's however I need more info on your TV, also size make model # anything you can provide gets us a more narrowed solution.
hope this helps....
Aug 17, 2008 | Philips Magnavox 51MP392H Rear Projection...
Cracked screen and down screen
If the double images are located at the bottom on one side, you might have cracked the mirror inside the set and it has been displaced making the picture in that area bad (especially if the rest of the picture is OK)
Dec 28, 2007 | Philips 60PP9202 60" Rear Projection...
Blue out of whack around sides
I have the convergence problem with the red. After reading your site I replaced the 2 ICs and the problem is worse. Before the only problem was I could not adjust the red horizontal. Now I have no control over the vertical or horizontal and the overall picture is very red and it bows at the top and bottom very bad. A friend said I might have the ribbon connector in wrong or the convergence (silver box?) box maybe bad. Any ideas? Thanks,Dave.
Oct 12, 2007 | Philips 55PP9352 55" Projection Television
Philips 27PT5445 27" TV Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
