Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Tur copier on and the mesage reads DOWN LOAD STANDBY Is this a fuser issue or is this something else ?
  • Bob Von Bruns Jan 12, 2009
    I could not get the copier to stop printing - asked for 5 copies and it tried to print 100. After pressing all buttons to stop the print without any affect, I turned the copier off. When turned back on the message reads Download Standby.
    This is not attached to a computer, being used as a copier only.
  • 1,219 Answers
Your copier system is crashed.You need to upload new firmware. call service.
Posted on Jul 03, 2010
How do I remover a fuser from brother MFC 7820N printer
Hold the release tabs down while you pull the unit out, Rich.
Aug 10, 2014 | Brother MFC Office Equipment & Supplies
How do I clear an error mesage E000
The E000 ERROR is a fuser problem. this happens when the fuser takes to long to come to the right standby temp.
I think a away around this would be to keep letting it warm up to the point it has hit the right temp by keeping powercycling it. I think though you will need a new fuser
Jun 24, 2011 | Office Equipment & Supplies
I am receiving the mesage "Replace supplies" ..... I don't know what supplies they mean. I read where I need to check the 'gauge' -- but I don't where to check it. Can you...
On the control panel, go to information>print supplies status. You will then get a sheet printed with the counts of fuser, transfer belt and toners. There is also the option to just view them as well. You can also press the help button (one with a question mark) and that should tell you what is wrong.
Jun 23, 2011 | HP Color LaserJet 4650DTN Printer
I have a HP Laserjet P3005dn and when it prints it is making a load grinding clicking noise. The paper comes out fine just the noise is the only problem.
The grinding on this model is caused by one of the gears that interfaces with the fuser wearing down. In the process it pushes the bushing on the fuser out of position. Replacing the fuser may resolve your issue, but you should really replace the fuser and the gear. When you take out the fuser you will see an assembly of 4 gears on the inside-left of the printer. The bottom-right gear is the one that needs to be replaced.
Feb 23, 2011 | Office Equipment & Supplies
Error message 50.5 fuser. what does this mean
This mesage means that the fuser needs to be replaced. It is esay to do :
Instructions are on this page:
I buy mine from them:
And you can shop here:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 22, 2011 | HP LaserJet 4350TN Printer
I have a hp 4L laser printer when printing some of the [rint on the page is fine but there are areas that are faded bafly unable to read this does this even with a new toner-what can I doto fix this...
If its a laser printer you prob have a fusing issue. Its the part that actually heats the toner with fuser agent (light coat of oil) to make it stick to the paper and not smear. Either your fuser module is in need of replacing or you have something rubbing on the portion where the toner meets the paper. Chances are its the fuser module.
Feb 01, 2011 | HP LaserJet 4L Printer
Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Apr 05, 2010 | OKI B6200 Laser Printer
My laserjet 2550 won't print. The light beside the triangle is blinking but I don't know what that means.
Hello there,
What is the color of the blinking light? Is it red or green? If its red, then there must be a cartridge issue or paper jam. Did you load the paper correctly? Also, please try to do a reset of the printer.
Aug 03, 2009 | HP LaserJet 2550N Photo Printer
Zebra printer problem
chek on setings if the sennsor is reflective, transmissive or auto.
should be on Auto. try to read the Sensor profile, and check if read the gap.
Try the Manual calibration, and then run the sensor profile.
tur off and on again.
Apr 25, 2008 | Zebra Z4M Printer
How to locate and replace copier exhaust fan
Hi, H3 is abnormal high tempeature in the fuser. Never had issues with the fan, probably you have a 'melt down', inspect the fuser through the sprung loaded flap and see if the three picker fingers that rest on the roller are melted. If they are then you require a fuser rebuild to include both fuser rollers, fingers, bearings and thermal fuse.
Feb 11, 2008 | Sharp AL 1631 Copier
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
66 people viewed this question
old marine
old marine
