Question about Pioneer VSX-818V-K Receiver
TECHNICS SA-DX850 F70
IT WORKS; BUT AFTER SOME TIME STOPS AND SHOW F70 ON DISPLAY. fuses are all good! otherwise it would not wor at all!!!
Enyone.
Or maybe someone knovs the voltages on emiters of tranzistors Q701 and Q708 (aprox +/-15V) i have +13,5 and - 16 and not stabile and i belive that may be a problem
  • Miladinka Dec 22, 2008
    It happens even without speekers, same
    Scholar:
  • 86 Answers
It could be an overload from two speaker wires crossing, check the owners manual for error codes.
Posted on Dec 22, 2008
  • 3 more comments
  • Sudo Bash Dec 23, 2008
    It could still be a short (overload) even if it is not the speakers that is just the most common cause of overloads. thanks for the bad rating on a free post though... I really appreciate it, but seriously check your system for shorts.
    Actually it could be a capacitor problem, open it up and look for ones that are bloated or look like they are ready to explode it might even be one with the top protruding slightly. A volt meter will allow you to test them and see if they supply a constant and stable amount of volts and amps.
    +13 and -16 should be fine... it fluctuates but to much fluctuations can mean bad components like capacitors...
  • Sudo Bash Dec 26, 2008
    I should rate your post as inappropriate for screaming and being a general @$$...
    Please also learn how to spell.
Its showing F70 error on display. Only workd on DVD mode, when i turn it on any other mode it just shows F70, switch power off. All fuses are ok, no any visibly damaged components
The fuse is a part of the problem it is for safety measures
the problem is in between the power supply regulators, capacitors and power amplifier circuit board.
usually a regulator or an output transistor can cause this error.
hope this helps.
Aug 08, 2014 | Panasonic SA-HE70 Receiver
I have a Technics SA - DX750 Amp Everytime I turn it on I get an error message F70 and then it requests that I turn the power off. This is all it does now, so sound. How do I solve this issue I have...
Hi!
The F70 error certainly indicates a blown fuse inside.
The real problem is why the fuse is blown: there are only two possible reasons
1. there is a short circuit on the output (lines or speakers)
2. you have a blown output transistor (and that means some work and skills to replace).
To be sure, please change the fuse with a same rated fuse (buy more than one because it can blow again). Disconnect the speakers and turn the amp on. If the fuse blows again, it is sure something wrong with the output transistors. If the fuse remains ok, then please check all the wiring to the speakers.
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Technics SA-DX950 Receiver
System overload (technics sa dx-850)
audio amplifier IC damaged need to be replaced
Sep 25, 2010 | Technics SA-DX850 Receiver
Problem with Technics SA-DX850
SA-DX750 (sister Model to SA-DX850). Showing error code F70, after a few minutes running. Checking the power rails revealed +5VA and +5VD, on the Digital Circuit Board 'A', dropping to about 2V, when fault occured. F5, T1A, on the Sub-Transformer Circuit 'M', was subject to occasional blowing. The problem was traced to an intermittent break, in the printed circuit board conductor, in the vicinity of Q1702 (+5VD regulator) collector, on the Digital Circuit Board 'A'.. Repairing this cured the problem. Note that removing F5 (above), or disconnecting CN702, CN1000A or CN904B, on the Digital Circuit board 'A', also causes this error code to be displayed. Failure of the audio output ICs, IC651 & IC801, is apparently the usual reason for this error code being dsiplayed, but it is worth checking the power rails viz. +/- 25V (Fuses F3 & F4, T6.3A, on Sub-Transformer Circuit 'M') +/- 55V, +/- 14V etc.
Aug 11, 2009 | Technics SA-DX850 Receiver
F70 on my reciever
Most likley it is in need of repair. I suspect the output IC. Check for bad solder connections on the IC and voltage regulators.
Remove the speakers and see if it still happens (it probably will).
Feb 11, 2009 | Technics SA-DX940
F70 problem
Look up "Panasonic F70 error" on Google and you will find plenty of discussion about this problem.
The F70 is a blown fuse error. It looks like you can can the fuse yourself, if so inclined, otherwise send it to a service agent.
Aug 03, 2008 | Panasonic SA-HE70 Receiver
F70
The system has detected a fault in the output section. How much are you asking of the system? Greater than 50%? That will push most systems to their limit in a short period of time...accordianman
Jan 14, 2008 | Technics SA-DX850 Receiver
Could anybody tell me what F70 means ?
You must have air flow through this unit!...accordianman
Dec 04, 2007 | Technics SA-DX850 Receiver
What is F70???
F70 means Blown Internal Fuse change the internal fuse and that should solve the problem if not you may have to change the output
Oct 30, 2007 | Technics SA-DX750 Receiver
F70 Error on SH-AC300
unit has a blown internal fuse. replace it with exact type of fuse and see what happens. if it blows again, it will need to be returned to a service agent
Sep 25, 2007 | Technics SA-DX950 Receiver
Pioneer VSX-818V-K Receiver Logo
1,372 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
