Question about Sharp XR-10X Multimedia Projector
Sharp xr-10x projector wont turn on - Sharp XR-10X Multimedia Projector
  • rp32250 Jan 22, 2009
    my projector won't power up the manual indicates a bad bulb is this true
  • Anonymous Mar 24, 2014
    SHADOWING ON IMAGES
  • 2,237 Answers
If there are no leds lit on the top, then probably the bimetal circuit breaker tripped. you have to take the top off to get to it. it's located on the front of the lamp housing. press the red button. if it still doesn't turn on, it's the power supply.
Posted on Jun 10, 2009
Problem with Sharp XR-10X The power light blinks red
According to the manual, a red blinking light indicates that the lamp cover is open. Try reseating the lamp and making sure everything closes up right. If the light is still blinking, it is most likely a problem with the projector itself and you may need to find out about getting it serviced.
Jun 27, 2011 | Sharp XR-10X Multimedia Projector
Unlock Sharp XR-10X-L Notevision Proj. says keylock function on
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
Apr 27, 2010 | Sharp XR-11XC DLP Projector
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
May 30, 2009 | Sharp XR-10X Multimedia Projector
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X projector, but missing the projector bulb.
if you plug it in and turn it on, you should at least hear fans running, then it'll shut down because there is no lamp. that's about it.
Apr 01, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Bulb works once then nothing
this is something which sharp didnt foresee!!!!!!!!!!
sharp has two identical models
sharp xr10x & the newer model xr10xl.both the lamps look alike , however both have a different rating & reverse connector!!
i.e both cannot be interchanged!however if u have the old xr10x & if u try to fit the new bulb which is lower in wattage, it will explode in 20 mins
if you have bought a used projector , then u wont know if someone has interchanged the ballast!!
as this model was discontinued 2 years back!!!!
so confirm the model , it is mentioned under sharp name or at the bottom
good luck
Feb 05, 2009 | Sharp XR-10X Multimedia Projector
Sharp xr 10x
You will need to open it up and flip this little breaker switch. It has gotten to hot and tripped itself. Dust it out while you are in there.
Apr 26, 2008 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
1,257 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
