Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Marco Model 7114741
Pilot light works, switch works, fire burns about 1 minute then goes out. Any help is appreciated. Thanks
  • Richard May 11, 2010
    Does the glass on the fireplace get really fogged up and do the flames apear to lift off the burner and burn more towards the top of the fireplace right before everything shuts off?
3 Suggested Answers
  • 63 Answers
SOURCE: Marco fireplace Model 794 cant light the pilot
the valve handle is on when the handle is in line with valve body, off when crossed...are you pushing in on the pilot gas valve under unit? if not.. open bottom panel.. turn knob to pilot..push and hold down while sparking..if pilot lights continue to hold for about 60 secounds.. then release knob and turn to on! Also FYI... these units have a vent recall on them! please go to google and type in your heater, then model #
Posted on Apr 06, 2009
  • 3082 Answers
SOURCE: Marco gas fireplace, pilot comes on, fireplace
Hi check pilot is clean , check the volts from the powerphile should be 300 to 500 mille volts ,seeif pilot flame is playing on powerphile
Posted on Mar 02, 2010
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
I have a Marco gas fireplace model# 794019C. It is the millivolt pilot generator type. I first changed the thermopile and cleaned the spark ignitor to get it to light. I have checked continuity and...
Mike, I suspect that the problem you're having is not related to the new Thermoplie (Pilot Generator) you installed. Its with the Thermocouple. The clue was "Some of the time its hard to keep the pilot light lit". The Thermopile controls the opening and closing of the gas valve, when the wall switch is turned ON/OFF. The Thermocouple, is what keeps the gas valve open and pilot light lit all the time. If there's no flame heat on the Thermocouple, it closes the gas valve. Rather than replace it, you can try polishing it with some very fine sand paper, then wipe the tip with a cotton ball soaked in alcohol. If the Thermocouple is really pitted, don't attempt this. Just replace it. If you do replace it, when you make the connection to the gas control valve, finger tighten the nut, then tighten only 1/4 turn more with the appropriately sized wrench.
By the way, MARCO is no longer in business as MARCO Fireplace. It was purchased by Lennox Hearth, a division of Lennox Heating. And your model firsplace is no longer manufactured. If you continue to have problems with it contact Angie Parrish at Lennox via email angie.parish@lennoxhp.com.
Hope this helped you solve the problem. Please be kind enough to rate my response to you. Thanks and have a good day!
Mar 25, 2011 | Heating & Cooling
The pilot light will not stay on for more than 5min. If I light the fire when its on,it just goes out. The fire is a Fusion 2/7
I assume this is a gas log? If so, you have dust in your pilot assembly. Turn everything off and let it cool. Note the opening where the pilot flames burns. Use the wand from your vacuum cleaner and place it over the opening for the pilot flame. Gently tap the side of the pilot assembly while holdign the vacuum above the opening. This will lift the minute dust particles out and allow the flame to burn nice and blue again. These logs have Oxygen Depletion Valves on them. The pilots are very sensitive to dust.
Jan 18, 2011 | Heating & Cooling
I have a model HE424M 33Mj/h gas Pyrox Firestar gas heater. I have just cleaned it and now it does not start. The pilot light is ok as is the spark but as soon as I let go of the centre button tha whole...
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out.
Sep 22, 2010 | Heating & Cooling
Marco gas fireplace, pilot comes on, fireplace fires up, after one minute the whole system shuts off. Why does it shut off after a minute?
Mar 02, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Furnace runs about 1 minute, then total shutdown
that sensor as you call it is a thermacouple it produces a small current which lets the gas valve know it is ok to open . if the pilot is not clean and correct it will not let main valve open. if your pilot is good then you have bad gas valve. you may have low gas pressure this can also do what you are describing
Apr 05, 2009 | Coleman Propane Forced Air Heater...
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Steve
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
