Question about Aerogrow International Inc. AEROGROW AEROGARDEN DELUXE - UPGRADE KIT - BLACK
Aergrow pump how do i clean out water lines and replace pump
    Sergeant:
    Champion:
  • 404 Answers
Pumps probally blocked,blow air down pump line.run oxy plus or mild bleach though system,rinse in fresh water after
Posted on Jan 05, 2009
Lavazza blue
First I'm a retired Cimbali tech but I've come across the Lavazza table models when they first came out. You should contact your vendor for help as there are no customer servicable parts.
*** The following is for information only ***
* Since you have already cleaned, refilled, restarted the unit several times (try up to 5 times at least) Then you will have to look for other problems.
* Make sure the water float moves freely in the tank compartment. It's usually a colored plastic part that moves up and down with the level of the water in the tank. If it's missing then the machine will think there is no water in the tank and not start up the pump system to prevent air from entering the pump lines. The unit will not power up unless it can sense this water float.
* Air bubble in pump. The vibration pump may have an air bubble in the pump valve. Starting and stopping the unit will help force the bubble out. But the pump needs to have clean water with no air in the water filter and the water line to the pump. It may take 10 or more tries to force this water out. Otherwise you will have to have a tech replace pump (re-building pump is very tedious).
* Clogged pump requires service to replace.
* Some models that come with a filter. Check and replace as needed.
Aloha, ukeboy57
Feb 10, 2018 | Coffee Makers & Espresso Machines
Water coming out of fuel line after cleaning out fuel tank and replacing fuel filter
Take the fuel line off at the throttle body and at the filter, then blow the line out backwards-push all the water out of the lines.
Dec 12, 2013 | Ford F-250 Cars & Trucks
Replace water pump torrent
drain coolant until below water pump level. loosen water pump pulley bolts.then remove drive belt by rotating belt tensioner.remove drive belt from the right of idler pulley.carefully release the drive belt tensioner spring tension.then remove water pump pulley bolts and pulley.remove water pump bolts and water pump pay attention to the position old water pump when removing water pump so you can line up new water pump holes to the engine. be sure clean engine water pump mounting surface use gasket remover dont scratch engine surface when cleaning removing old gasket material. take new water pump gasket get it mounting holes line up with new water pump mounting holes.when done getting engine water pump surface clean.water pump gasket paper you need to put thin layer of sealer on both sides of water pump gasket use RTV SILICONE.LET SET UP 10 MINUTES. PUT GASKET ON WATER PUMP BUT FIRST MAKE SURE LINE UP GASKET HOLES WITH WATER PUMP HOLES BEFORE PUTTING ON THE GASKET SEALER.when gasket sealer set up 10 minutes then install new water pump with gasket to the engine torque to 89 inch lbs.or 10 NM that is about 7 ft lbs torque.you should be able turn water pump by hand if you cant turn water pump by hand got too tight damage water pump shaft bearing.when all done wait for THREE HOURS. before adding coolant i let RTV CURE SOME. torque water pump pulley bolts 18 ft lbs.
Dec 28, 2012 | 2006 Pontiac Torrent
After replace the cold water pipe line, my Grundfos recirculator pump does not work anymore. I have to wait 3 min to get hot water. Do you know anything wrong here? Thanks
Many times when pipes are worked on, the work loosens sediment that was built up in the pipe.
Sediment is probably why cold water line was replaced.
That's why faucet aerators get clogged up after pipes are worked on.
It sounds like your grundfos pump got clogged too.
Immediately unplug the pump so motor is not overheating.
Motors are meant to turn freely and can be damaged when blocked.
Take apart the pipes at grundfos pump and see if you can clean out the line.
If line cannot be cleaned or pump doesn't restart, then the grundfos has to be replaced.
Also look at adjoining pipes and see if there is a clog in nearby elbow, especially where galvanized and copper pipes join..
Dec 26, 2010 | Grundfos UP15-10B5/ATLC 1/25 HP ...
Not spitting forcefully
check supply line both ends at the angel and the pump , flush angel with clean water, clean pump screen replace line , make sure pump intake is always submerged
May 08, 2010 | Hagen Angel spills Water Spitter
NO DRAIN ''nd'' error MESSAGE
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 15, 2009 | Washing Machines
Aerogrow International Inc. AEROGROW AEROGARDEN DELUXE - UPGRADE KIT - BLACK Logo
319 people viewed this question
Top Aerogrow Garden Experts
roeb
john h
Marvin
Marvin
Are you an Aerogrow Garden Expert? Answer questions, earn points and help others
