Question about M-Audio FireWire 410 External Sound System
Sound System Sounds cant be played on the comp .. it says I need a mixer device... n then when i add it... it doesnt have it.. n the sound device or w/e... i couldnt install it or something... i tried everything but nothings working
  • dilshad Dec 17, 2007
    sound and audio devices not supported
    Problem Solver:
  • 3 Answers
Could problem be in motherboard config? i.e. if using motherboard sound hardware turn on in config, if using sound card, make sure motherboard sound hardware is off in configuration. it sounds simple, but after almost 15 years of building comps, i still get it wrong sometimes.sometimes
Posted on Apr 08, 2007
SOURCE:
My sound is not working, it says i need a mixer device?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
Jun 19, 2012 | Dell White Slimed Inspiron Mini...
I cant get the djio to play through my mixer
i have the same problem. My wild guess is incompatible dj software and numark drivers. i am using vdj pro 7 but i tried to downgrade to 5.02. and use single output ---------- headphones -------------- two cards, and assigned them to numark usb audio device, and the sounds goes thru my mixer. but when i use the vdj version 7 or higher cannot produce a quality sound. it got some noise coming out.
Apr 11, 2011 | Numark DJ/iO Sound Card
My toshiba laptop will not for some reason play sound. i have checked to see its not muted but it still doesnt work. any help?
Go to control panel > sounds and audio devices and have a look in there or click on the advanced button for the audio mixer. in the mixer, go to options > properties and select all the devices, close that and then turn up the volume on the mixer.
Dec 01, 2009 | Computers & Internet
It about mixer device
that is a motherboard problem. The good news is that you can add a sound card to your system and disable the built in sound for relatively low cost.
If you find this helpful please rate fixya.
Thanks
May 06, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
My computer wont play sounds it says i need a mixer or something, i formatted my computer yesterday and upon getting it working again i have had no sound... HELP?
Probably just need to update your drivers.  Check your device manager and if you have any yellow exclamations in the sound section.
May 02, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
No sounds,no active mixer devices,no audio devices,cant use volume control
uninstall the sound driver in the device manager and download the latest audio driver from the support site and install it.
Apr 25, 2009 | Dell Dimension 3000 PC Desktop
Sound Device not working but everything seems to be installed and working
you might want to try going into the bios of your computer (usually pressing delete when your computer first comes on) and looking in there to make sure your sound device is turned on.
Oct 14, 2008 | Toshiba Satellite A100-S8111TD Notebook
There are no active mixer devices
Sounds like you might just need the drivers restored for your sound card.
Try downloading the driver for the sound card by clickingon this link
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=57707
If that doesnt fix it you migh have the device disabled in the bios.
Try the drivers first then let me know if it works and we will go from there
Aug 21, 2008 | Dell Latitude C640 Notebook
Sound
first all make sure sound driver is the real issue. You can start playing a sound file if it visually plays, check the volume control (physical dial and mixer). If playback attempt comes up with sound device error you can easily download the driver from http://support.toshiba.com
Free of charge
Good Luck
Jul 26, 2008 | Toshiba Satellite A100-S8111TD Notebook
Sound driver problem
I'm not sure of your operating system so i couldn't go any further than here but this link should have all the software you need as well as manuals
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2229&lang=eng
Oct 31, 2007 | Intel D101GGC Motherboard
Open Questions:
M-Audio FireWire 410 External Sound System Logo
60 people viewed this question
Top M-Audio Computers & Internet Experts
Thomas F. Schneider
John Bolton
bigdaddyd2
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
