Question about Oster 6327 4-Slice Toaster
Broken Oster 6327 toaster
Hi.  I have a toaster that just stopped working.  when I try to engage the toaster lever it won't stay down.  I am a bit handy but I don't know so much about circuit boards and such.  I took the bottom off and cleaned it out and plugged it in.  It sparked a bit then began to work.  It did one round of toast and now it doesn't work.  It isn't that old and I hate to throw it out.  I have had toasters that have lasted for decades.
Thanks for any help.
SOURCE: Oster Toaster
The color code for R-3 is BRN-BLK-RD-Gold. 1K ohm. DD
Posted on Jul 17, 2007
Ian Prins
  • 11 Answers
SOURCE: Toaster Setting
No, you can not restore the settings, the best thing to do is go on ebay and buy a new one.
Posted on Dec 08, 2007
SOURCE: Trying to fix my Oster 6309 and can't seem to remove . . .
Mine is not working either. I can drop out the bottom and see the circuit board but have no idea what to do next. Mine no longer sensors the toasting time and I burn everything now...
Posted on Jan 28, 2008
My Oster Toaster stopped popping up after a couple of years as well - the lever just stays down until you unplug it or the toast catches on fire.
R3 was burned and replaced per the info on these discussions to no effect.
So I mapped out a rough schematic from the board and found some interesting things. Oster seems to be directly rectifying the line voltage (dangerous but cheap) through D1-D4 into 5V through DZ4 and 32V through DZ1.
These voltages seem to be across R3, which means it has 27V on 1K or about 0.73W on it continuously! Not only is this a waste of power, but it will always burn a 1/2W resistor. I would recommend replacing it with a 1W or larger and setting it up off the board to dissipate the heat into the air.
Then when toasting, the NPN transistor Q2 pulls to GND one side of the coil that holds the lever down. R3 is used as a series current limit for the 32V supply to the other side of the coil (so it has 32V or over 1W on it when toasting).
My problem with the toast not popping up was related to Q2 being blown. I don't remember the original number since I cut it out, but they seemed to have used an audio transistor with a Vce of 20V and Ic of 20mA. No wonder it blew with 32V and 32mA on it - bad design from the start.
I replaced Q2 with a cheap, commonly available 2N2222 - it has the same pinout and is good for 1A and 50V. It's been working great for months, but sadly still burning almost 1W continuously or over 6KWh per year.
-Jeremiah
Posted on Jul 19, 2008
  • 6 Answers
There is a mini adjustable potentiometer facing the left side on the circuit board. Turning it counter clockwise to your taste.
Posted on May 15, 2009
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
www.dummies.com/how-to/content/how-to-fix-a-broken-toaster.html
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
https://www.youtube.com/watch?v=QKiJkpuHy-Q
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
Lever does not stay down. Does not toast
Hi
This is a common problem after heavy usage. You need to open the toaster and adjust the lock which holds the lever in place. Which is connected with the Thermostat, as the thermostat trips it will pop the lever and the Mechanism connected out.
Aug 01, 2011 | Oster Kitchen Appliances - Others
6331 will not stay down
I have the 4-slice oster, but I bet the control mechanism is the same. When you take it apart you will see a small steel bar held by two plastic fingers. When you push the lever down the steel bar moves down and contacts a small square electromagnet. The electromagnet holds the lever down during toasting and releases the lever when done. On mine there was a compressed layer of bread crumbs covering the electromagnet. Cleaned it off and now it works again.
To take the toaster apart, pull the down lever straight out and then unfasten the screws on the bottom base (5 on mine) and pull the top off carefully. There are wires connecting the control face to the base, but they have enough slack to let you separate the top/bottom and access the mechanism.
Nov 24, 2009 | Oster 6307 / 6309 2-Slice Toaster
Our toaster stopped working a little while ago, but it is outside the (presumably) one year warranty period. It's a 4 slice, soft touch black toaster, cost about £75, I think it is this model. It only...
remove from the electricity supply
remove crumb tray,
remove bottom 4 os 6 screws.
at the bottom of the toaster there is what liooks like a flat fish hook that engages with the handle when you push the handle down to start toasting. clean around this and try to get it to engage when you push the handle down, it wont stay down unless the electricity is connected but dont plug it in as you will probably kill your self!!
put it back together abd try it
if it does not work 4 slice toaster from Tesco £9.99
Nov 09, 2009 | Dualit 45375 4-Slice Toaster
The digital control panel is on the fritz,
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down--and none of the buttons were functional.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Nov 28, 2008 | Oster 6330 4-Slice Toaster
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
Dec 27, 2007 | Kitchen Appliances - Others
Toaster lever
I have sunbeam model AGW toaster level is not staying down and no power. the spring work, i want to know what part hold it down. please help or there any repair company i can take it (s. california) thanks
Dec 17, 2007 | Kenmore KTES4 4-Slice Toaster
The lever actually comes off another way, turn the toaster upside down and you will see a small clip holding the handle to the metal arm inside, you can pry it off with aa small screwdriver
Nov 17, 2007 | Oster 6307 / 6309 2-Slice Toaster
Toaster broken???
these toaster has to be pluged in so that the lift lever could stay down.
Feb 23, 2007 | Kenmore KTES4 4-Slice Toaster
Lever won't stay down Breville CT20
hi sounds like the problem is the holding down mechanizem clean the toaster well find that spring which caches the lever down you can find it on the external lever side pretty small and simple thing when you push down the external lever the spring kick a little lever which holds the slide in place for heatup only when you will hear a "click" then you'll know its in place and then the electric cicuit will be close and engage the coils to heatup good luck
Mar 30, 2006 | Breville CT20 Retro Classic 2-Slice...
Oster 6327 4-Slice Toaster Logo
53 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
