Question about Intertherm P3RA-048K Air Conditioner
Furnace blowing cold air
Intertherm furnace wont ignite and when switched on it blows cold air...
  • 67 Answers
THERMO
Posted on Jan 07, 2009
  • 242 Answers
Hello , I think I can help , It sounds like the gas valve as long as your sure there is plenty of gas going to the unit and you have an electronic ignitor , if there is a pilot light its not electronic. the gas valve should come as an assembly to install and its pretty easy to complete. Let me know if you need more help. Good luck
Posted on Dec 30, 2008
I have an intertherm furnace model number 901282 and it will not heat my house when i turn on the thermostat it starts but just blows out cold air pleases help
The blower should come on after ignition occurs. When the blower comes on first ignition will not be activated as the thermostat signal shows the heat is on. This happens when the blower relay is stuck in the on condition
Nov 21, 2014 | Intertherm Heating & Cooling
Turn power off & on again. Watch to see if it cycles...it could be the hot surface igniter if you don't see it turn bright orange. If it goes straight to blowing cold air, then normally it is a limit switch open- mostly manual reset - thermal disc-located around flame rollout.
Dec 20, 2013 | Ruud RGTM10ERBJS 100K BTU 95%...
Furnace lights blows heat in cycle, pops sensor on blower and continuosly blows air until button on sensor is pushed back in
You are over heating because of dirty filter, coils, or bad or collapsed ductwork check return especially. on the units data label there should be a max and min temp rise this is the difference from incoming and outgoing air through the furnace. Check this.
or it could actually be a bad switch.
Oct 25, 2012 | Intertherm 56000 Btu Gas Furnace
Intertherm mmha070
Hi, did he bypass the high limit to see if it was bad? Sounds like you are getting false codes and you have a problem in your module or main board, which ever you have. The way it is acting, saying the high limit is open but the tech says its not, I would change the board.
Shastalaker7
Nov 14, 2011 | Intertherm P3RA-048K Air Conditioner
I have an intertherm furnace it is blowing cold air it will not ignite
You should check to see if the igniter Or so called glow coil is cracked in half or is broken anywhere. but be very carefull it is fragel but can be removed for inspection.
Jan 03, 2010 | Heating & Cooling
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
The Intertherm AC Model B3BV-030K-A is blowing warm air
If you don’t see any frost on the suction line or big line on the furnace
(that goes from the furnace to the outdoor unit) and the filter and coil are clean then you are probably low on refrigerant.
Apr 14, 2009 | Heating & Cooling
My Heater blows cold air
is this a gas furnace if so does the burner ignite
Nov 25, 2008 | Intertherm P3RA-048K Air Conditioner
Furnace fan running off and on blowing cold air
Need a little more info. Does the fan never stop? Is this a gas furnace? Is your thermostat in the fan auto not fan on position?
Dec 08, 2007 | Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
378 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
