Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf620 aquarius very noisy and not letin any water in
Ive lost my manual an my washing machine has been very noisy for a while now and now
wont go onto a normal program it went onto prewash and then all the lights on all the buttons came up when it finished it was bone dry
  • 679 Answers
A washer usually shakes or vibrates when it isn’t sitting firmly and level on the floor or because it has an out-of-balance wash load. First eliminate the possibility of the latter—adjust the load if it has scrunched up on one side of the tub. Then check the machine for solid, level support. For the machine to work properly, the floow must be flat, level, and strong enought to support the heavy, water-filled washer without deflecting under the load.
1) Unplug the washer.
2) Look under the washer, and make sure all feet are resting firmly on the floor.
3) Make sure the front legs have locking nuts to keep them tight and that the legs have rubber caps. If they don’t, buy these parts and install them.
4) Make the front feet as short as possible by screwing them up into the machine. Place a level on top of the washing machine and adjust the front feet slightly if needed to level the washer; do not fully extend them.
5) If necessary, tilt the washing machine forward. This will let the back feet self adjust. Recheck for level, and adjust the front feet again.
6) Plug in the machine, and run it empty through the spin cycle to see if it still vibrates.
7) If it does, call a repairperson or the manufacturer to ask about solutions.
Thanks for your question
Posted on Jan 03, 2009
My hotpoint washing machine WF620, squeeks when it is washing and spinning
On most hotpoint wash machines you cant replace or grease the bearing you have to replace the whole drum which cost around 100 pounds from hotpoint and a couple of hours labour its a common problem on hotpoint machines.
hope this helps.
puggy
Jan 07, 2014 | Hotpoint Aquarius WD63 Front Load...
Aquarius wf620 super silent washer has "test" in
  • to de- activate press and hold the start/cancel button untill all the lights come on.
  • then press and hold the on/off and start/cancel buttons together until d-off appears
that should do it and if not get back to me, there is another way you can do it.
Jul 11, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius wf620 washing machine,machine very noisy when in high spin working ok when golng through program
While spinning every washing machine is very noisy as it rotates in very high speed.This is normal and no need to worry.
Thank You
Sep 08, 2010 | Hotpoint Washing Machines
Hotpoint washing machine model WF620, keeps reading TEST when you select the programme.
depending on which version you have to
Press the 'Start / Cancel' button until ALL the console LEDs illuminate.
then either
1.Press both 'Start / Cancel' and 'On / Off' buttons together until 'd OFF' appears.
or
2. Press 'On / Off' and 'Start / Cancel' together with the top left option button (Spin) until 'd oFF' appears.
Mar 14, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf620 indicating f-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Jan 24, 2010 | Hotpoint Aquarius WD63 Front Load...
Noisy when spinning
bearing gone cheaper to buy a new one
Jan 23, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF620 - flashing error F05
This is a drain problem. Most likely something caught in the pump which is accessed by removing the small panel at the rear/bottom of the machine. The pump slots in place and can be removed by lifting and shifting to the left. Unscrew the pump off or remove the pipes will reveal all.
Dec 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint washing machine model aquarius+1200 spin wf620
F03 indicates an open or short circuit thermistor, this is associated with heater element, so probably the water is not getting hot.
You need to check the heater and thermistor unit. access is from the rear.
Hope this helps.
Plz leave feedback
Ta.
Dec 09, 2008 | Washing Machines
Hotpoint Aquarius WF000 Front Load Washer Logo
163 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
