Memorex tv/dvd will not go off of input avi 1
When I turn on the TV it tells me to Please Wait. It does this for a while then it goes to AV1 and you cannot change the input.Checked the cable box all connections it is all fine, cannot even get to the channel menu. This is a Memorex TV/DVD combo.
I KEEP GETTING A BLACK BOX ON MY TV. I HAVE A SHARP MODEL #32RS400. ANY SUGGESTIONS?
Posted on Jan 24, 2009
What does AV1 mean on a SAM*TRON TV mean? How do I get rid of it?
av 1 is the source input for the tv
there should be av 2, 3 4 etc and each one isa for a different input item
for example av1 is for the tv -aerial , av2 may be dvd input , av3 may be x box, av4 home theater
how to get rid of it . click on exit or ok
Sep 30, 2016 | Televison & Video
My sony dvd is not playing on the tv. all cables are color coded and plugged in correctly
Look at the guide below use AV1 or AV2
Match the colors vertically
Click on "INPUT" key a blue screen will appear Choose AV1 or AV2 according the connection you have made at rear panel
Please let us know the outcome so we can try alternate ways to help you.
Good Luck
Jul 02, 2008 | Televison & Video
Tv avi display flashing despite svideo & avi inputs connected
Are all the inputs not working correctly, or just the AV?
If its just the AV it could be a cable issue, try a new cable. If still a issue try a different input device (DVD player etc)
If still a issue then its most likely a issue wit the TV.
What type of TV is it, depending on the make and model you may be able to get a replacement part
Jul 08, 2016 | Televison & Video
I have the 3 RCA red, yellow, white cables on back of dvd and to tv. Video only plays when I select video 1 under the input. When when I select video 3 only sound and no video. What else can I try?
Sounds like from the symptoms that you have plugged the white and red cables into AV3 input on the back of the Teleivsion and plugged the yellow cable into AV1 on the back of the Television.
Check the cables are all plugged into AV1 input ports on the back of the Television. Red and White go into the Audio inputs and Yellow goes in the video input. Also make sure you have not plugged cables into component inputs on television look for AV1 in on back of Television .
Mar 08, 2015 | RCA Televison & Video
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
We drop the tv apex 27" gt2715 model and looked in the back of it and a plug that is red and white is a lose but we have know idea where it goes
Do you have DVD player attach to the TV?The RED and WHITE RCA plug are for RIGHT and LEFT sound channels, they must be from the DVD player, inthat case, you should also look for YELLOW RCA jack which should connected to the VIDEO/AV1, or VIDEO/AV2. The RED and WHITE RCA should be plugged into the VIDEO/AV1, or VIDEO/AV2 AUDIO INPUTS.
Please tell us more what kind of setup that you have.
Please read the owner manual.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 14, 2010 | Televison & Video
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
No picture no sound
Make sure you are selecting the correct input on your TV for your TV tuner, sat or cable box.
There are three ways to do this:
1. With the tuner or cable box turned on (you can do that manually or with its remote) use the TV's remote to cycle through all the inputs, until you find the correct one and take note of the name of the input that appears on screen, or
2. Look at the back of the TV and see where it is connected. It will say the name of the input, such as "HDMI1" or "AV2," etc. Then select that input on your TV with the cable or sat tuner turned on, if you have one.
Consult your TV's owner's manual, which will give more information on hookup and selection.
Hope this helps. :)
Nov 17, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Nov 03, 2007 | Pioneer HTD-510 System
My Screen Said "Are You Sure" and "Please Wait" and now, instead of "AV", i have "AV1" and "AV2" and my tv wont show picture from the dvd player OR vcr
You will need to go back into the menu and see what ia available in the video input mode. You may have switched the type of input you can use such as default or componts ect. If you have an isntruction manual, look in there or call the manufacturer, should also be in the instruction or user manual. Good Luck
Mar 28, 2007 | Spectra KT2114 Television
Televison & Video Logo
Top Televison & Video Experts
