Question about Roper MHE14XKB Microwave Oven
Window in the door has slipped down two inches.
How do I get at the glass and then how do I secure it?
  • Roper Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Chances are that the holding tabs have broken off the inner door panel. Unless you can use epoxy or some other material to fabricate new tabs, you'll have to replace that panel.
Posted on Dec 25, 2008
The outside glass on the microwave door has slipped down. Is that dangerous and can it be fixed?
Its not real good as it could shatter if door closed hard and there to protect against microwave radiation on the front.
A repair shop who looks at this will know first if door can be opened up and fixed or the door will have to be replaced.
Dec 17, 2012 | Goldstar MV-1615 Microwave Oven
Goldstar Mv1526W
is the lock/screw was loose//?
Jun 11, 2008 | Goldstar MV-1526 Microwave Oven
How to replace inner glass panel on Neff H7871 microwave
Hi Bill, I am having a same problem I have managed to order the glass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, the door should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slip in hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner door behind it.
5. Remove the 16 screws holding the inner glass with a special star type screw driver bit no T30.
6. Once you done that the glass housing holding the inner glass can be carefully prised free and taken off the inner door assembley.
7. Once you done that remove and inner glass, and be carefull to leave the glass glass seal intact, clean around the frame housing and the seal then replace the new inner glass and reverse the process.
PS. Becareful of the inner door once you've removed the outer door, as the hinges holding the inner door tend to shut quickly as there is less weight on the hinges.
It will do the job if you follow these instructions.Good Luck. AL
Oct 10, 2011 | Neff H7871 Convection/Microwave Oven
Microwave door glass has slipped down into the frame
What usually happens is there are tabs on one of the inner door panels that holds the glass up.
If one tabs breaks, the other one soon will, then the glass slips down.
If the mesh / screen is still in place and undamaged, and the door is otherwise undamaged, there shouldn't be any leakage.
You or someone you know may be able to take the door apart and use epoxy to fashion new retainers for the glass.
Or you can usually order the specific door panel piece that you need but if you want to, please reply back with your brand and model number so we can help you.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Jan 07, 2009 | Microwave Ovens
Neff H7871 inner glass broken
Hi, I am having a same problem I have managed to order theglass from:-
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, thedoor should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slipin hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner doorbehind it.
5. Remove the 16 screws holding the inner glass with a special star type screwdriver bit no T30.
6. Once you done that the glass housing holding the inner glass can becarefully prised free and taken off the inner door assembly.
7. Once you done that remove and inner glass, and be careful to leave the glassseal intact, clean around the frame housing and the seal then replace the newinner glass and reverse the process.
PS. Be careful of the inner door once you've removed the outer door, asthe hinges holding the inner door tend to shut quickly as there is less weighton the hinges.
It will do the job if you follow these instructions. AL (srahbah@hotmail.com)
Dec 05, 2008 | Neff H7871 Convection/Microwave Oven
Microwave door has burn spots on the glass of the door...
i have the same problem, there is a brown spot about 3 inch
by 2 inch at the bottom of the glass, I cannot clean it, it looks
like its in between the glass.
May 01, 2008 | Whirlpool MH6150XMS Microwave Oven
Loose glass in door
Silicone glue would be best since it has very good heat tolerance and, if the clear is used, there will be no problem with it absorbing energy but I wouldn't use any with colorant as it could have metallic pigments.
Dec 23, 2007 | Whirlpool GH7145XF Microwave Oven
Glass front on door unglued
First: do not use this unit with the glass improperly installed. Often, these installations use double sided foam tape, available at any hardware store. Carefully remove the screws in the door being careful to catch the glass. Clean the area where the tape will go with glass cleaner or alcohol. Allow to dry and buff to remove oil and grease. Install the tape and glass. Reassemble.
Dec 18, 2007 | Maytag MMV1153A Microwave Oven
Door glass
You should be able to find helpful exploded view diagrams if you enter your full modle number (more that 5 digits) here: http://www3.sears.com (the 3 is correct)
Nov 20, 2007 | Kenmore 62702 Microwave Oven
Door outer plastic plate slide down an inch from the top
You would probably need a service manual, for which you can contact LG at 1-800-243-0000 or http://us.lgservice.com
Or locate a local servicer:
http://us.lgservice.com/gcsc/b2c/hpi/main
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Nov 19, 2007 | LG LMV1645 Microwave Oven
Roper MHE14XKB Microwave Oven Logo
52 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
