Question about Intel D845PT (KD845PTPAK10) Motherboard
Acpi compliant bios acpi compliants
    President:
  • 2,692 Answers
BIOS has no upgrade for VISTA to be installed. Contact the manufacture to write on update BIOS for that computer or motherboard as the case may be.
Posted on Dec 22, 2008
The bios in this system is not fully acpi compliant
Guess your computer is not compatible with Windows 7. Reinstall windows XP run compatibility test from Microsoft
May 16, 2014 | Dell Inspiron 15 (N5050)
Bios is not ACPI complaint
It's possible that the BIOS setup has been accidentally set to non ACPI mode. Check in the setup to ensure ACPI is enabled.Other possible causes are memory expansion, overclocking and incompatible driver software. Check out what you have recently installed or updated on your computer.This can occur if Windows has detected that the BIOS in the computer is not fully compliant with Advanced Configuration and Power Interface (ACPI). To correct this problem, contact the manufacturer of your computer to obtain a BIOS update that is fully ACPI compliant. (If your PC is an older model, a BIOS update may not be available). There are third party companies that will write a BIOS update for your computer for a fee which may make it more cost effective to replace your computer.You may also find help on this Microsoft Support Site.
Apr 09, 2013 | Computers & Internet
BIOS Acpi Not Compliant
You will need to go to the website for the motherboard manufacturer and download the updated drivers for that motherboard. This is common with all the changes that windows goes through in a life cycle.
Nov 23, 2011 | Computers & Internet
ACPI Compliant
Don't worry check out on the net about this motherboard, put that serial number of the mother board on the site and download the BIOS drivers. update that BIOS by DOS prompt , problem will be solved
Jun 15, 2009 | Computers & Internet
ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
Jun 01, 2009 | MSI Computers & Internet
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
RESOLUTION
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
Mar 16, 2009 | Dell Inspiron 1100 Notebook
How to install Windows Vista On IBM NetVista 830331G
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Feb 10, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Acpi complaint - reg
I have located some info on this board. it was released as a "Medion" board
there is some BIOS and driver stuff available HERE
http://www.medionusa.com/ and select customer care.. you need the exat model no or the serial no of the PC to continue though.
Also http://www.treiber.de/ may me of assistance as I think they are the real manufacturer but as I cannot read German I cant really be sure. they have the link to Medion on their webpage...
HIH and please post back results
Jun 23, 2008 | Intel Motherboard
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
41
Jan 17, 2008 | Intel Motherboard
Intel D845PT (KD845PTPAK10) Motherboard Logo
93 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
