Question about Cuisinart DCC-1200 Coffee Maker
Coffee brews cloudy
I just bought the DC-1200 model and followed the instructions before using it. When I brew the coffee, it comes out extremely cloudy looking, like it has coffee grounds in the coffee. Can anyone tell me why this happens?
  • 8,596 Answers
If the coffee grains are too fine, it will flow through the permanent filter. Use the paper filter instead. Also, make sure the lid is on the caraffe tight, or the filter basket will back up.
-Tha Mp3 doctor
Posted on Jan 09, 2009
Cuisinart dc 1200 coffee maker auto start mysteriously shuts off
Sounds like the switches got damp when you cleaned it. Let it dry out very thoroughly before you plug it back in. Then set the TIME OF DAY first, and be sure you pay attention to AM/PM if you are not in the 24-hour mode. Next, set the BREW TIME. Once again, heed the AM/PM or you will have nice hot coffee either 12 hours early, or 12 hours late! (I don't know which would be worse.)
Mar 18, 2012 | Cuisinart DCC-1200 Coffee Maker
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
Aug 16, 2010 | Cuisinart DCC-1200 Coffee Maker
I just bought a a cuisinart dc-1200 coffee maker ,the problem is after the coffee is made the basket if full of coffee water????
mcdevito75 here, Either a defective machine or you could be over-filling with water at the start of brewing.
Jun 22, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee Maker have problems starting and in some cases stops in the middle of brewing.
mcdevito75 here, It may need to be cleaned, water used to brew coffee leaves deposits in brewing holes, refer to owners manual for cleaning instructions.
Jun 20, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
My grind and brew turns itself off in the middle of brew cycle
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir as a guide rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. As such, a 12-cup machine actually produces closer to 9 standard 8 oz cups. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. It is extremely important to clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Ensure that the coffee machine is sitting level on the counter.
May 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart automatic grind and brew
Clean it out with vinegar and water - 2 ozs distilled white vinegar, 2ozs water
Dec 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Will not brew
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Sep 02, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart dcc 1200 will not brew
I'lm not sure of the model, but it is a Cusinart Coffee Maker with a Glass Pot. It gets power on all lights except the ON/OFF switch, and it willl not brew. Any suggestions, or should I trash it and get a new Coffee Maker. This one is approx. 1 year old. Thanks for your advise.
May 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
337 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
