I just replaced the color cart. on my hp offivejet G85xi 3 in 1 mach. now i get "press enter to alain cart." msg.when i press enter, it prints a page( i think its only a partial one), but the screen stills shows the same mag. i have cleaned the cart., replaced the cart. with the "empty" one and paid fixya 10.00 . the fella at fixya e-mailed me back and said to press the options and set up buttons at same time, but i cant find the set up nor the option buttons?? kent
  • khart35810 May 11, 2010
    i went to ur preminum program and got it solved. BUT i feel i got snookered with the first program , i was told to call an 800 number which told me they only work on program problems not hardware. so thou im pleased with jonniewalker's help, i feel riupped off for the first 9.99 kent
HP G85xi remove and check color cartridge message
Hi you can remove your Printer cartage and look see
ink points (dots) you can erase ink point and reattach your cartage your printer its Ready to use.
Jul 06, 2017 | HP OfficeJet G85 All-In-One InkJet Printer
Alainment problem, replaced the black cart. and now I can't the colors to alian properly. when doing the alianment test the 2nd black and blue line print a solid black but the blue is fussly..when printing...
This could be due to a problem with the printhead or the cartridges try doing a clean printhead by going to the Lexmark productivity studio or Center. You can clean the contacts of the cartridges by following this instructions. http://bit.ly/9UGXvc
Feb 23, 2010 | Lexmark X5470 All-In-One InkJet Printer
HP G85XI Printer
Replace both ink carts with GENUINE HP ink carts.
Mar 09, 2009 | HP G85xi All-Color InkJet Printer
Hp G85xi ink jet printer. Keep getting the
Possible your printer is equiped with by optical sensor of the determination to density of the paper. If he was littered by dust, that you it is necessary to clean his(its) compressed by air.
Mar 06, 2009 | HP G85xi All-Color InkJet Printer
No Macbook Driver for HP G85xi
Do an internet search on gimp print, there are 3rd part sowtware solutions to this.
Dec 20, 2008 | HP G85xi All-Color InkJet Printer
Selecting two-sided printing for a office g85xi printer
Here is HP's document on two-sided printing:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu03059&lc=en&dlc=en&cc=us&product=58305&rule=5715&lang=en
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 31, 2008 | HP G85xi All-Color InkJet Printer
Printer cartridge missing
Make sure ur using the correct cartridge.....
for X2580 the cart number is 2 and 3
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts
Clean the ink nozzel using a wet paper towel.....do not whip it ..just press and hold the nozzel....do this 3 or 4 times....
then
Install the carts...
open solution center.....click maintence tab...click on "clean to fix horizontal streaks"...
-----XXXX----
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
HP OfficeJet K60 Printer
you can bypass when asked and use last good settings by..Press and hold the Enter button, and then press Menu
This problem is caused by incorrect alignment page print out caused by faulty cartridges, ideal fix is replacement of all ink carts
HP have a webpage dedicated to this...h10025.www1.hp.com
Also get on your gloves get out your vac and suck on the carts till a little ink comes out, make sure colour cart releases all 3 colours then reinstall, can get messy.
Oct 19, 2007 | Office Equipment & Supplies
Printer issue
I can only suggest that you should use genuine HP ink carts. Try all new carts and realign again. Hopefully it is under warranty. HP is good at exchanging.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 02, 2007 | HP PSC 2175 All-In-One InkJet Printer
k24674
jasbo
jasbo
Marvin
Marvin
