Always crank motor over by hand with a ratchet or breaker bar before attempting to start with key. You can very well ruin or lock up your motor if the timing is incorrect before you try to start with key. If its locked up, unhook battery. Place ratchet and socket on crank pully. rotate in reverse and then try to rotate forward. If there is anything holding the motor from turning by hand, pull timing belt and make sure everything is aligned correctly and try to crank by hand again 2 or 3 revolutions. If tight or locked, then motor needs inspected for bent, jammed valves, broken pistons.
