Question about Toshiba 42H81 42" Rear Projection Television
Wavey Picture I have had my Toshiba for about 5 years, when I turn it on the screen is all wavey and it takes about 15 minutes to get a clear picture. I am just wondering if anyone has had this problem, is it worth trying to get it repaired and is it a costly repair?
  • dleviticus Jan 01, 2008
    My tv showed wavy tight lines til it warmed up, then became more and more clear. Over 3 mos. it took longer and longer. Today after 2 hours, It is still jumpy, w/ small sharp waves. Any ideas? If it will cost 3-400. I feel like getting a flat plasma.???
Was told that these parts are no longer available from Toahiba.
Posted on Jun 07, 2007
    President:
  • 3,130 Answers
The hyper or scan converter module is bad in this set. You can certainly have this set repaired and will run about 275 to 350 depending on where and who does the repair. Good Luck
Posted on Apr 08, 2007
Toshiba sl738b
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Toshiba Televison & Video
I have a toshiba satellite L505-S6946 that is a year old and now I have a blue screen. what does that mean and how can I get it repaired. Thanks
try with an external monitor (connect an external via 15 pin's output of your laptop)
if it worked, monitor of your laptop is damaged and you can only take it to a guarantee center.
and if it doesn't work:
1- open back lid of laptop.
2- evolve the battery.
3- wait 15 minutes.
4- put the battery.
5- turn on the laptop.
and if it doesn't work, take take it to a guarantee center quickly.
Jan 11, 2011 | Toshiba Satellite L505-S5966 Notebook
Horizontal wavey lines in projection TV picture
what brand? could be a ground problem or bad crt
Aug 22, 2009 | Televison & Video
I have a toshiba big screen with three bulbs and the picture has wavey lines on the screen. Does this mean tubes are going out?
Most of these Toshiba sets have a "hyper board" that processes all the signal and a lot of them are going bad---lots of surface mounted filter caps on the board dry out and usually it begins that lines in the picture and after several minutes the problem slowly clears up and or goes away---as time goes on it takes longer and longer for it to go away----For most of these sets the only way to repair is remove the board and send it out for rebuild--rebuild of the board and labor may be more then the TV set is worth.
Jul 10, 2009 | Toshiba 42H83 42" Rear Projection...
My Toshiba 57H81 has a 'jittery' picture.
I have the same prob need to change the resistors as a first resolution. there should be 5 of them, if you dont soon and i mean soon you could cause the skt to go bad and have to start over in your repair
Mar 08, 2009 | Toshiba 57H81 57" Rear Projection...
Wavey lines
Sounds like your set has dried caps in the Power Supply, take it to a decent tech, its not something you should try to do yourself as dangerous voltages can still be present evn if the set is unplugged.
Jul 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba 57HX81 is all wiggly and distorted (youtube video attached)
I don't know about that. Someone probably was rough with it and messed them up. You should have a technician look at it.
Jun 16, 2008 | Toshiba 57HX81 57" Rear Projection...
Wavey picture
Zebra19. This problem is a common occurance in these sets. So common that there is a service bulliteen to service centers on it. Fixing it is not easy though. It ivolves 11 very very small micro capacitors. on what is known as the hypermodule. In an ideal world replacing the hypermodule is the best course of action. but.. these are almost impossible to find. if you are very good at soldering and have a lighted magnifer and very small twezzers it can be fixed. but if you damage the board....... i have done this repair about 6 times.. replacing them is what need to happen. 11 10 microfard surface capscaae315.jpg this is the hypermodule ... it is a board in a sheilded can that plugs in behind the input termals in the back. kind hard to get too. the caps are the small circular components that you see with the red and black marks on it.
willie at fordtv.com
May 19, 2008 | Toshiba 57H81 57" Rear Projection...
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
218 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
