Question about Harman Kardon CDR2 2-Disc CD Recorder
How do I record on my Harman Karman I can't remember?
I haven't used in a while and i need help?
Put a blank cd in the right deck; put the one you are recording from in the left deck. Close door. Punch dub.. after it scan all the tracks, then punch play/select on the right hand side, then it will dub it for you. Once it gets thru dubbing; hit finalize - lights blink twice, then hit finalize again. once lights go out it's finished dubbing and you can play it back to hear your recording...
Posted on Jan 14, 2009
Looking for an internal parts diagram for a Harman Kardon CDR2
Where do you live? Sarasota electronic has belts if its wrotten take machine and belt I am in florida
Apr 03, 2013 | Harman Kardon CDR2 2-Disc CD Recorder
I have a harman/kardon class 2 transformer model# 661520oo3ct. It was with my computer equipment but not hooked up. I don't remember what it was for. what uses does it have?
hi,
it comes with ur desktop speaker harman kardon hk 206. it is a 12v 1A dc power supply. u can use it in any equipment which needs that power rating. only thing to remember is, check the polarity of both before connecting.
ok
Dec 17, 2010 | Harman Kardon HK206 Computer Speakers
I have a Harman Kardon CDR 30 that I use to burn my analog Vinyl and cassettes to CD. I have done this successfully for years. I recently got a reel to reel deck and unhooked all the components and moved...
do you remember how your connection was before the RR tape deck? if so connect it back that same exact (when every thing was recording / playing) way as before....(you also need to purchase 4 gold tip "y" connector jacks (2 RCA female to 1 RCA male)) ... in / out jacks you just plug the cassette deck will be shared with the RR tape deck...just note you will not be able to record from cassette to RR tape or vice versa...but you will be record from all other sources...
feel free to rate the help
Mar 27, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Do harman karman soundsticks light up
Hi:
The set of soundsticks I owned did not light up, and I don't think that they made any that did...!
Nov 17, 2009 | Harman Kardon SoundSticks II Computer...
Need starchoice codes for Karman Kardon AVR 220
http://www.starchoice.ca/english/customercare/techcentral/remote_controls.asp
Look here for the codes to whatever remote you have. The chances are there arent any though. Harmon Kardon codes are a very unique signal that most remotes cant duplicate. More than likely you are going to have to use the original Harmon Kardon remote.
Oct 24, 2009 | Televison & Video
Does anyoe know how to record from LP to cd?
Use your tape out, or another line out signal from your preamp.... if possible - OR Sometimes you can pull out some connectors on the back of your amp (a Metal joint kindathing ;), to break signalpath between preamp and poweramp if its an integrated amp -
Use preamp out signal to feed your cdr ( Main purpose is to equalize out, the RIAA correction on a record)
Have you tried to google your question ? Lots of fine guides out there!!!
Jan 14, 2009 | Harman Kardon CDR2 2-Disc CD Recorder
Harman karadon cdr26 recording problem
try to download and install a clean version of aspi32 drivers,  http://www.adaptec.com/en-US/speed/software_pc/aspi/aspi32_exe.htm
Nov 24, 2008 | Harman Kardon CDR30 2-Disc CD Recorder
Harman Kardon CDR2 2-Disc CD Recorder Logo
193 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
