Question about Ovens
Oven door hinge failure
Left hand hinge of door to lower oven (Creda Continental-10yrs old) loose and sags. Not obvious how to repair. Any advice please
  • Ovens Master
  • 3,463 Answers
U need to replace both door hinges together.
In your browser bar , type in youtube.com
Then in then search box type in fitting oven door hinge
Click on appropiate video and follow instructions.
This should be a big help to you.
Plz rate my solution.
thanks.
Posted on Dec 31, 2008
Unable to remove oven door (to fix misalignment). Old Smeg oven
burnt grease make things sttick really well . try some wd40 on it for a day or so then open part way and pull up on the door .
Nov 09, 2016 | Ovens
Why does oven door stick out at the top about 1/2 inch when closed?
then call him back to fix what he forgot to do Adjust it
Oct 28, 2015 | Ovens
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
Miele classic h 383 b-cat Oven door will not seal properly. Checked seals and cleaned around hinges. No obvious signs Help Thank you
SPRAY HINGE WITH WD-40 AND SEE F THERE ARE ANY SCREWS OR BOLTS AT HINGE THAT ARE LOOSE OR THE HINGE IS BAD,GRAB IT BY THE HINGE AND SHAKE TO SEE IF IT IS LOOSE.THE HINGE PART THAT GOES INTO OVEN THAT YOU CAN NOT SEE COULD BE LOOSE OR ENLARGED TO MAKE IT NOT LINE UP.
Nov 17, 2012 | Ovens
My JenAir oven door doesn't close fully
most likely you have bad door hinges if the door doesn't close correctly,i don't know if you know this but alot of parts are no loner available for this model,it must be old,the only thing you can get for the door is the hinges and that's it,you'll need the rest of the model number to get the right hinges you're missing the last two letters,you can go here put your model number in to look up parts.
https://www.searspartsdirect.com/model-number/JMW8527CAB/1266/0125300.html
go to door and look at part 16 the hinge,hope this helps you out,when you open the door,if it sags down lower to the ground the hinges are bad,when open it should be at a 90 degree angle
Feb 01, 2018 | Jenn-Air JMW8527C Electric Double Oven
The hinge to close the oven door came loose from the oven how do we fix this
Oven doors detach by lifting. take the door off and it should be obvious what to fix. Be careful when handling the hinge as it has a strong spring and can give your fingers a real wack.
Jan 04, 2011 | Whirlpool Ovens
CREDA BUILT IN DOUBLE OVEN MIRROR FRONTS 2002 MAIN OVEN FRONT FAILED AT METAL TO GLASS HINGES IS THERE HEAT RESISTANT ADHESIVE OR WILL ARALDITE 150 C SERVE ?
Araldite will not do the job sati8sfactorily, as it it will not remain flexible as the oven gets hotter.
Go to the E-Bay site and look for high temp silicone adhesive for oven glass doors.
It is about£5.00 + p/p.
It is perfect the repair you need to do, I have used it myself, and recommend it.
Mar 27, 2010 | Creda Ovens
Can I get replacement door for my top oven, and new door seals for Creda Cachet Solarplus Model 48182, serial 60.1.00082
we should be able to help if you contact the office
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Ovens
Faulty oven door
This IS SO EASY !! I have the DACOR 48...no tools, 5 minutes and you are done! It took me 8 years of frustration and I fixed it TODAY !!
Just open the door, latch the small hook that binds the two hinges together. Next try to slowly close the door until resistance. Just when you think you might break something push up another 2 inches. Now lower the door , unhook the latch to seperate the hinges (latches) nad PRESTO a snug fit !!
Dec 19, 2007 | Dacor ECS127 Epicure Stainless Steel...
Ovens Logo
408 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
