Question about Philips DECT 2252S Cordless Phone
Base station and units all say 'searching'
Philips CD245 cordless phones: just plugged into power for first time.
All3 units and the base station say 'SEARCHING'
  • 71 Answers
You may need to register your handset to the base.
Normally ,there is a advanced setting ,register handset. At the same time, press and hold "page" key on your base 4 to 5 second , there is be a registation success tone from handset. You can register all of your handset ,one by one. Some model need to input register code, normally ,it is 1234 , or 0000.
Posted on Jan 21, 2009
It really wrk 4 me !! Thank you
Posted on Apr 13, 2012
PHILIPS CORDLESS CD245 TRIO AND other 2 handsets power requirements (Adapters lost)
It should say on the bottom of the base unit. I would expect 5-6 volt 500ma. That would be the size that would charge those batteries.
Oct 16, 2016 | Philips Lands Phones
Uniden dwx207
When a handset is reading "Searching", it can't communicate with the base. First, check if the base station is plugged into a live outlet. (Try plugging the base into a different outlet or making sure that the circuit breaker hasn't popped. I had a cordless phone base plugged into a UPS. During an extended power outage, the UPS was turned off. The phone didn't work until someone noticed and turned the UPS back on.) Move closer to the base station.
If this was an extra handset purchased later, make sure it is compatible with the base station. The Uniden DWX207 works with the DECT1500, DECT2000 and DECT3000 series bases. Register the handset with the base. The registration procedure depends on the base station. If the base unit has an LCD screen, with the phone in standby, press Menu/Select and press the down arrow to reach "Register Handset". Then press Menu Select again. (If the base doesn't have an LCD screen, unplug the power cord. Then hold the Find HS or Find button as you reconnect the power cord until the Charge/In Use light starts to blink.) Then press the # key on the handset before the registration period ends.
Make sure that you haven't exceeded the number of handsets for your base. You may need to de-register all handsets and then re-register them.
If no handsets will pair with the base, replace the base unit. The transmitter or the receiver aren't communicating properly with the handsets.
I hope this helps.
Oct 06, 2013 | Lands Phones
Can I use Philips CD240 CD245 handset on a philips dc445 base
Simple answer yes they are compatable I just did it as I could not find any CD445 handsets.The manuals are downloadable from Phillips just search for CD445 or CD245 manual.Just press speaker button on 445 base for 5 seconds untill it beeps twice,then on new 245 handset menu/ register enter default code 0000 and bingo its live. Oddly the newer handset bases are 9v and not compatable with 445 bases which are 6v and have different contacts so you cant sit your 245 in the old base.My new 245 came with a new base anyway so no problem.
Apr 06, 2012 | Philips Lands Phones
HI! I have a Philips CD245. It seams to be that the base unit is dead or about to die!!...I conect the power and the light goes on very weak for abou 1 or 2 seconds. What component is not working fine? I...
Hi marybls ,
I am afraid this is a sign that the internal board of the main base unit is either corrupted or rusted. i would highly suggest for you to take it to an electronic shop to get it repaired as no further solutions can be given on line.
i hope this helps.
Mar 28, 2011 | Philips CD2451S 1Line Cordless Phone
Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
Mar 13, 2011 | AT&T CL82409 Cordless Phone
Philips cd245 trio flashing searching all the time wont let me reset the system
Sounds like the main phone doesnt have a connection or is unplugged. Do you get a dial tone when you pick it up?
Mar 01, 2011 | Philips CD2454B05 Quad Cordless Expansion...
My house phone keeps saying bs search and wont call out or recive calls
bs meaning of course - Base Station...
There is no link between your cordless set and the base station, hence the message.
I would do what SpencerR stated, try to re-establish the connection via the base station to accept the handsets again.
Have the cordless sets worked before?
It may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless sets, and take out the batteries in the cordless set. Wait for about 15 seconds for all the power to drain out of the sets, and re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link to the cordless sets.
Good luck
May 11, 2009 | Lands Phones
Philips CD245 Cordless Twin
just one phone displaying unregistered
Sep 28, 2008 | Philips DECT 2252S Cordless Phone
Philips DECT 2252S Cordless Phone Logo
1,164 people viewed this question
Top Philips Lands Phones Experts
Marvin
Marvin
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
