Backlight off and can't get it on again.
Here's what it is,
I was just scrolling around on the settings menu and I turned the backlight off. Now, I can't get it back on again. I tried the apple manual solution by pressing any button to turn it back on but that doesn't work. What do I do?
Either clean the screen or navigate the iPod by heart. Try pressing any button and it should come on
Posted on Dec 24, 2008
My sansa clip will play music but the screen will not light up;
There's a timer for the display backlight that can be set and used for
saving power. When leaving the player untouched for a certain time, the backlight switches off. Touching any button will turn on the backlight, restarting the timer.
To set the backlight timer on the Sansa Clip,
execute the following steps:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
Dec 24, 2009 | SanDisk Sansa Clip MP3 Player
Pictures turn out red with backlight need to turn if off
Go into the menu and scroll to "reset" and follow the on-screen instructions.
Nov 20, 2009 | Panasonic DMC-TZ5 Digital Camera
Is there any way of turning on the backlight on the numeric keypad on the u600?
From your main menu go into "Settings". Select.
Scroll down to number 5 "Light settings. Select.
Scroll down to number 3 "Keypad light". Select.
It will probably be set to "Night time" 05:00 PM.
Use your direction pad to change it to "Any time" Save.
The keypad backlight will be on all the time.
Aug 17, 2009 | Samsung SGH-U600 Cellular Phone
Lc32gd8e backlight goes out in middle of a program
This is not a complete solution, but I have found that once the backlight has gone out, I can normally get it back by selecting the "Audio Only" option in the setup menu without turning the set off. This option is really intended for use with radio broadcasts when the picture carries no useful content.
When I press the 'menu' button on the remote and select the right hand most tab, the top option under this tab is 'Audio only'. I select the tab, and then exit from the menu until I need it. When the backlight goes out, I press the following key sequence:
menu, down, ok, right, ok, menu
and the picture reappears. Pressing the menu button opens the menu page at the correct (righthand most) tab. the down highlights the 'audio only' option, and the OK selects this. The right turns the option on (with the backlight working, the picture is removed, but the menu is still displayed). The second OK activates the option. The backlight is turned out. Finally, the second menu key press turns the backlight back on again. This technique has the advantage that the sound continues throughout the sequence, and the recovery of the picture is faster than waiting for the set to boot from a power off condition.
I suspect the problem is caused by an intermittent contact on one of the tubes, possibly as the result of some movement as the tube warms up and expands. (There are 8 tubes in the 32" set.) This causes a safety ciruit to shut down the inverter supplying power to the tubes. Switching off the backlight resets the safety circuit. If I manage to confirm this suspicion, I will write again.
Jun 12, 2009 | Sharp Televison & Video
Proscan Tv is humming
This made my humming sound go away completely;
From JD at oncorpus.com [manufacturer of the 32LB30Q]
Please follow these instructions, should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
Dec 15, 2008 | Proscan 32LA30Q Television
30k gb bla
iPod has backlighting, so you can see the display in low light.
You can configure iPod so the backlight turns on for a set amount of time when you press a button or move the scroll wheel.
To access the backlight settings:
  1. Select Settings > Backlight Timer.
  2. Select a setting from the menu. Options include having the backlight timer:
    • Off
    • Turn off after a period of time between 2 and 20 seconds
    • Always on
A backlight on/off switch can be added to the Main menu by selecting:
Settings > Main Menu > Backlight
Jun 02, 2008 | Apple iPod MA446LL/A MP3 Player
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
IPod Backlight Broken
I thought my ipod was broken but i did something to make it brighter:
Go to settings and scroll to brightness (i guess it should be right under backlight timer in the menu)
There you will need to scroll clockwise and you will see your screen get brighter.
Anyway I have a ipod video I'm not sure if it's the same as the other ipod series.
Apr 24, 2008 | Apple iPod MA446LL/A MP3 Player
Series Back Light
It is possible that by holding the power button down too long, that you turned off the backlight. When you hold down the power button, a menu eventually comes up with "Backlight Off" highlighted. The easiest way to undo this, is to simply do a soft reset. Or, you can hold down the power button again, and "Backlight On" will be highlighted (if there's enough ambient light you can see this message); just tap it, and the backlight will come on again. Also check out your backlight settings by tapping: [Start][Settings]tab[System][Backlight] the tab [Battery Power] should be highlighted; adjust as desired. Next tap the tab [External Power]; adjust as desired. Finally, tap the tab [Brightness] and make sure the sliders are high enough.
Sep 07, 2005 | HP iPAQ H6300 Pocket PC
110 people viewed this question
 Grubhead
Grubhead
