Back to:
Tags:
Jenn-Air JES8850 Electric Kitchen Range
My downdraft fan does not run.
posted by ppatty on Apr 08, 2007
This is a new range that we purchased freight damage, and have replaced front door glass. But everything is working fine when we installed it, but the fan does not run. We think it may be the wiring, but we are not sure. Any ideas?
Comment by ppatty, posted on Apr 08, 2007
the model number is wrong. It is a JES 9750bab. Thanks.s.
Comment by ppatty, posted on Apr 10, 2007
I guess I didn't explain it very well. I have the Jenn Air with the downdraft. When I turn the grill side on, the downdraft fan does not run, nor can we get it to work just turning the fan on high or low.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 09, 2007
Thanks for Trying (70)
tresilla
Rank:Guru Guru
Rating: 86%, 1189 votes
i assume you mean the oven fan. does the element heat or not. first thing to check that you have the clock set properly because you may have it set to auto withiout realising
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on My downdraft fan does not run.:
I don't want to Accept this solution
Can you Help with these Kitchen Ranges problems?
I spilled some grease and it ran between the glass on the...
A bowl in my microwave leaked water on top of Jenn-Air...
I have an Admiral stove. I need to replace a burner...
I have a Baumatic gas hob, although all the control knobs...
My control panel paint is peeling off. The rest of the...
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
