Question about VMware Workstation 4.x (WS4-ENG-W-CE) for PC
Hey So I am running my XP partition from VM Player in Linux and everything was working fine until I installed Fix-Ya expert tool and it crashed both the Normal and Virtual parts of my XP partition. So I uninstalled this tool in safe mode and it still would not boot, in fact it gave the quick BSOD: Stop: 0x0000008E and would restart immediately... My question is do you know of any one else that has had any issues with Fix-Ya expert util? After I did a System Restore to before the fixya util was installed it worked fine...
    Renaissance:
    An user who is expert in 3 categories / brands.
  • VMware Master
  • 1,302 Answers
This might help
https://support.microsoft.com/en-gb/help/315335/-stop-error-code-0x0000008e-or-stop-error-code-0x00000050-page-fault-in-non-paged-area-error-message-during-windows-xp-setup
Posted on May 06, 2017
2 Suggested Answers
  • 51 Answers
SOURCE: virtual box last working verry slowly on linux fedora
Could be a problem with the RAM allocation for the OS. Try allocating more ram and try.
Posted on Dec 30, 2009
Laptop random shutdown: Safe-mode; Linux
Did u dual install Linux and 7 on 2 different Partitioned Drives?
Is it only linux with the problem or is windows playing up to?
possible a bad install of linux as a OS?
Try uninstalling linux (leave windows) and partition the hardrive (making 2 different drives i.e. C and D on a single Physical Hard Drive -- its just divided into 2 parts)
and try running Linux from a single clean hard drive and leaving Windows seperate.
that MIGHT solve ur problem. gl.
Mar 17, 2014 | Computers & Internet
I have downloaded Ubuntu Linux 12.04 and am running it under wondows xp sp1. How can I delete windows and just run Ubuntu ?
Here is what you need to do:
1. Open 'GParted'. From the menus: System -> Administration -> GParted
2. Right click on the ntfs partition and select 'delete'
3. Right click on this deleted partition and select 'Format to' and select ext3. This should accomplish what you want.
If GParted is not installed, then open a terminal window and type
Code:
sudo apt-get install gparted
And then proceed with steps 1-3 specified above.
PS: Backup any data you need from the WinXP partition before you do this.Alternately, instead of formatting the XP partition to ext3, you could do this:
Using gparted, as described above:
Right click the XP partition and click delete.
Right click the Ubuntu partition and click resize
In the resize dialogue, change the settings to that it is as big as possible.
Click apply changes.
This is riskyer, so BACK UP EVERYTHING!!!!!! I do not take responsibility for lost data.
This however will be closer to "unpartitioning" the drive, what was suggested above will still result in it being split into two partitions, they will just both be linux partitions.
Oct 27, 2012 | ValuSoft Ubuntu Linux for PC, Mac, Linux
WINXP-_CRASH
I wonder if you ever pay attention to what you're doing; if you install a Linux Distribution, it's going to have a non-NTFS boot sector, and moving Windows' original boot sectors around is not guaranteed to work well.
If you pay attention to what you're doing, you should be installing Linux on a fresh disk using a good filesystem like ext3 or ext4 or Sun's filesystem. If you want to run WinXP rather than run applications (games, etc.) under WINE or a VM, you can use Disk Commander or such to boot to the old drive and mask the OS from each others' existence. Likewise you could install, run, etc. Fedora, Ubuntu, etc. from within a VM in WinXP; or install, run, etc. WinXP within a VM in a Linux. If you don't pay attention to what your install means for the system operation, you're going to get surprised.
Feb 13, 2010 | Microsoft Windows XP Professional SP2
How to Install both XP and Linux?
I would install XP 1st then Open suse or Ubuntu. When you install either of these linux OS's ensure you install to another partition other than the windows one. Both installation routines will allow you to format the drive to the linux ext2 format and automatically install a boot manager (usually GRUB) which will allow you to select the OS you wish to boot.
Aug 09, 2009 | PC Mall Ubuntu 8.10 for Linux
VM XP Lin FixYA Crash
did you go to programs in the control panel , highlighted the fixya line and uninstall to remove fixya program
if all you did was delete the icon, you will still have the faulty program running
May 08, 2017 | VMware Workstation 4.x (WS4-ENG-W-CE) for...
Cannot run Fujifilm Software for FinePix with Windows Vista
1) If you right-click on the executable file, can you use the
"Compatibility" TAB to run it as an XP program?
2) Many XP device drivers will fail to install or execute properly
under windows VISTA, and I suspect it is the camera's USB
or Fire-wire (IEEE-1394) based device driver that is causing
the problem, not the main application.
Unfortunately there is NO easy solution for this,
except to get an upgraded software package (for Vista)
from the Camera Manufacturer.
3) There are also two possible work-around(s), but both require
some knowledge and software installation:
DUAL-BOOT
Install both Windows XP and Windows Vista on your
computer using two separate hard-drive partitions, and
a boot manager.
A partitioning tool like "Norton Partition Magic", formerly
"Power Quest" or "Acronis Tools" can be used to partition
the hard-drive non-distructively (your data is preserved):
a) Resize (shrink) the existing Windows partition.
b) Create a new partition for Windows XP (about 10 Gigs)
c) Install Windows XP-Pro onto the new partition,
d) Add both the XP and Vista partitions to the BOOT.INI
file on the boot drive.
Both windows XP and Vista do have multi-boot capability,
but the Windows XP boot manager may not recognize Vista,
in which case you may have to re-install or re-pair the Vista
installation. The Vista boot manager will recognize WinXP.
Running VISTA is generally a bad idea, because it is obscenely
slow and inefficient compared to XP, and because it is infected
Microsof't draconian and arrogant copy protection schemes,
known as DRM = Digital Rights Management.
Towards this end, Vista also insists that all installed multi-media
devices must be "Recording Industry" compliant and approved,
to make music and movie piracy more difficult. Many media
copying programs and CD-rippers will also refuse to run,
by design.
All this "Added Technology" is stealing your money, your
computer resources, your performance, and your right to
backup your media, at your expense, for the benefit of
the movie industry Mafia.
Use Vista only when you have to, boot to Windows XP for
most of your applications.
VIRTUAL MACHINE
Both Microsoft and VM-ware (as well as others) make
a software product called a Virtual-PC, which allows you
to emulate multiple operating systems under windows,
including older windows, MAC and Linux.
VMWare is by far the best, the most reliable and the
most flexible, at about $200 US.
Martin
May 07, 2008 | Computers & Internet
About Linux fedora and XP
Without knowing more about your system, the key rule is to install XP first, then Fedora.
If that doesn't work then it's time to put more partitions on your hard drive, and install the 2 operating systems on different partitions, again, remembering that Windows XP has to be the first installed.
Mar 31, 2008 | Intel D102GGC2 Motherboard
Acer Aspire 4720 RHEL4 Installation
again install linux in between the installation there will be option select linux boot loader , and one more think linux partition space should more then windows partition
Mar 26, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
Top VMware Computers & Internet Experts
matt
matt
CarlosIjalba
Tproverb
Level 1 Expert
Are you a VMware Computer and Internet Expert? Answer questions, earn points and help others
