My ALT button seems not to work, This is on my Toshiba A200 151 (laptop). I have cleaned the button via removing it then cleaning and putting it back in place.It seems i might have to check F - lock problems but i do not know how to access them.Please help
  • Dan rogers
    Dan rogers May 11, 2010
    how can you tell your alt key is not working, what signs is it giving you?
  • 942 Answers
Hi caza0121, try to power drain your pc.
Turn off the laptop, remove the cables on it, then remove the battery
Push and hold the power button for 5 seconds, then replug the cable and reinsert the battery and turn on the pc.
Hope this helps....
Posted on May 08, 2010
How do you repair a lapptops wiped hard drive
reformat it and reinstall the operating system via the cd slot
on start up hold down the alt,ctrl, and delete buttons to get into the bios the select boot from cd
once the os is in then close down and open it again and do the 3 button entry to bios again and change the selection to hard drive for boot up
you will have to re enter all folders and programs as a wiped or formatted HD is clean to start with
Mar 01, 2016 | Toshiba Satellite Computers & Internet
How do i fix toshiba satellite C850D laptop some keys not working
1) open the buttons and clean underneath them by a toothbrush.
or
2) remove the keyboard (you can see how to remove it online or get back to me if you can't find it) and clean the wire belt gently, maybe something is stuck in there.
or
3) if the above didn't work and you don't want to spend money on a new keyboard, try using a keyboard app.
or
4) the best desperate solution (which i used to solve my problem) is to use SHARP KEY app, which enables you to switch a key to an alternative, less used button.
Mar 06, 2015 | Toshiba Satellite Computers & Internet
My toshiba satellite c56-b5246 wont turn on....I was skyping and watching Netflix at the same time and when I woke up my laptop was off....the power button lights up when I touch it but it only blinks...
Maybe the computer's memory or RAM is the problem,, try cleaning the pins of your RAM using a clean white pencil eraser,, if it doesn't work,, try replacing your RAM with a different RAM from other unit just to test if it is the problem, or put the RAM on other slot.
If none of that works,, do the same way of cleaning and replacing the peripheral video card (if any),, or tighten the connection of LCD to the board.
Jan 24, 2015 | Toshiba Computers & Internet
How do I access/clean keyboard toshiba p55t-a5116 with harman kardan
You can remove the keyboard and then blow everything clean with canned air. Go here for help - http://cpufandeal.com/toshiba-satellite-p55t-a5116-laptop-cpu-cooling-fan.html
Dec 30, 2014 | Toshiba Satellite Computers & Internet
My VPCEB1J1E Laptop Suddenly Freezes While Gaming!!!
SOLUTIONS
1.USING PROPER ANTI-VIRUS EG:KASPERSKY
2.DISMANTLE ALL THE PARTS AND PUT BACK (NEED A SPECIALIST) BECAUSE ANY LOOSE IN CONNECTION DUST PROBLEM CAUSES TO MAKE COMPUTER SLOVER
3.USING ADVANCED CLEANER SOFTWARE EG:CC CLEANER PRO ( PRO ONLY HAVE ADVANCE SETUP )
4.CLEANING DUMP FILES
Eg: TEMPS,DISC CLEAN UP> C:/ > PROPERTIES > DIC CLEAN UP
GOOD LUCK BRO
Jun 12, 2013 | Sony Computers & Internet
My toshiba l675d-s7013 laptop screen won't come on?
hi
turn off your laptop take out the battery and hold the power button for 20-60 secs to discharge it and then put the battery back in and reboot or remove the battery and the ram clean the ram or try another stick of ram then press the power button and see if that restores your laptop.
if not plug another monitor into the external vga port, if the external monitor works then your laptop screen is faulty.
if the external monitor is also black or blank then the inverter inside the laptop needs to be checked or replaced.
cheers
Dec 02, 2012 | Toshiba Satellite Computers & Internet
How to clean the fan on a toshiba satellite
If you do not want to tear the system down, just power the laptop down, remove the battery, push the power button for 10 seconds to bleed off the power . Now go and get some compressed air used to clean electronics,you can get it in cans at an office supply company. Using short bursts, blow air in the laptops ventilation grills, using short bursts will keep condensation from blowing out and onto the laptop and also keeps the fan from free spinning and damaging itself. Blow air in all the grills several times over, that mosts the dust and hair back and forth and works it out of the grills, fins and fan blades.
Nov 26, 2009 | Computers & Internet
Toshiba satellite P305 ''Q'' key
if u can get ur keyboard replaced then why r u settling for a broken one??
May 14, 2009 | Computers & Internet
Toshiba Satellite: A135-S4427 / Won't shut down
by pressing the power button in, the computer has gone into standby or hibernate mode.
Heres what you Do:- press and hold the power button for between 10 to 20 seconds.
that should bring it out of hibernation.
if that does,nt work. remove the main battery.
when you,ve resolved the problem, run a disk-scan via your windows operating system.
Mike @ Compurepair.
May 12, 2008 | Toshiba Satellite A135-S4427 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
