Question about Timex T42351 watch
I have a Timex T42351 tachymeter chrono alarm wristwatch which needs the time adjusting. Unfortunately, only the hour hand moves (also altering the date). I need to adjust the minutes. How do i go about that?
This watch has a cool feature that allows you to change only the hour if you are changing time zones. But if you want to change the minutes as well, then pull the crown out farther. You'll find that it has four positions: Normal, pulled out one notch, pulled out two notches, and pressed in to turn on the light.
Cool.
As long as we're at it, notice the crown in the four o'clock position also has three positions. In: set alarm. One notch out activates an alarm including the hour and minutes. Two notches out only activates the minute setting, so you don't have to move the hour hand all the way around.
Also cool.
Posted on May 22, 2009
My Timex Chicago watch just arrived, it works perfectly, but the chronograph second hand is not pointing at the 12th o'clock mark. Is there a way to fix that?
normally the watch chrono hands can be reset .
dependant on movement fitted.
*pull crown out to first position
* push and hold top right pusher.
* the second should start top sweep one complete revolution and then stop.
*when it stops use the lower right pusher to adjust.
*when at the 12 push the crown but in fully.
Aug 28, 2017 | Timex Watches
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
How to set alarm in timex t42351 watch
Hi rplokin,
I finally found the user's guide for your timex watch. I am attaching a picture of it, download the picture and view in full size to see how to set an alarm on your watch.
i hope i solved your problem, please vote and rate me.
Regards,
Salman
Feb 13, 2011 | Timex T42351 watch
How do I calibrate the compass on a Timex Adventure Tech Digital Compass wristwatch?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please
Mar 14, 2010 | Timex T42371 Digital Adventure Tech...
Need to reset the tachymeter on my Guess Steel watch . The dial resets it's self to the "7" location instead of "12" on my watch. Is there a way to recalibrate the watch?
This is chronometer that's need reset. Tachymeter is usually located on bezel or inclined ring and is used for speed calculations of moving object over the given period of time. Ok, back to your chrono hand resetting. Pull out crown and then push the upper button and hold it. The chrono hand should start move and you should be able to adjust it. If this doesn't work, try the same with lower button. When adjusted - push the crown back in. In fact there are very many variations how to reset chrono hand, but exact advise can be given if the movement caliber of particular watch is known.
Rate me, plz.
Jan 11, 2010 | Guess Stainless Steel Chronograph Watch...
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
Nov 22, 2008 | Timex 1440 Nylon watch
Luminox 8152 chrono
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
Jan 02, 2008 | Luminox Field 821 wristwatch
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
CHRONOGRAPH
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Timex T42351 watch Logo
1,211 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Geoff
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
