Question about Panasonic KX-FL511 Plain Paper Laser Fax
Black line I have a Panasonic fax machine KX-FL511 and when I send faxes there is a dark black line down the right side of the page. I just replaced the drum and toner but it is still there. I also cleaned the thin strip of glass on the machine and it still there. Any ideas?
  • rhenry31 Dec 29, 2008
    So what you are saying just replace the machine? Or is it worth replacing the LED segment? So there is nothing that can be cleaned to fix this problem?
  • rhenry31 Dec 30, 2008
    thanks for your help.
    Genius:
  • 2,120 Answers
Probaby an LED segment is burned out in the scanner assembly.
Posted on Dec 29, 2008
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Apr 13, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
I have an hp kx-fl511 fax machine. Has new toner
Hi!
Try to reset advanced features to their default settings
RESET=NO [±]
To reset the advanced features:
1. Press {MENU}.
2. Press {#}, then {8}{0}.
3. Press {A} or {B} repeatedly to select “YES”.
4. Press {SET}.
5. Press {SET} again.
6. Press {MENU}.
Thanks
Rylee
Mar 18, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Pana KX-FL511 will not take mlt. pgs to copy, black lines, hot
It's time to upgrade. The THERMAL head is about to **** out.
Jan 30, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Apr 05, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
BLACK INK LINES ON INCOMING FAXES KX-FL511
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Oct 01, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Sending and Copying Problem
THE SCANNER NEEDS CLEANING HAPPY FAXING OMNIPRESENT
Mar 27, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
265 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
