Question about Sharp AR-M205 Copier
Red toner light flashing
Changed the toner cartridge. Red light keeps flashing and CH appears on panel
    President:
  • Sharp Master
  • 990 Answers
Dear sir; CH appears on the window means somewhere the door didn't close, when you close all door the red light will be disappear. try it out and let me know if you need more help, good luck, DON'T FORGET GIVE ME A RATING, THANK YOU , HAVE A HAPPY HOLIDAY !!!
Posted on Dec 22, 2008
I changed the toner cartridge and now it won't print. The red round light on the control panel is lit. Now what?
If the round red light you describe is a circle of dots that indicates a developer change is due. This needs to be done by a technician but the machine should work fine without doing the developer change.
Nov 10, 2017 | Sharp AL 1631 Copier
The photocopier keeps flashing a red light and have no manual
If light is blinking it can mean a few things like the toner/developer (TD Cartridge) needs to be changed soon or the drum needs to be changed or there is a paper jam or misfeed of paper.
Nov 04, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
When should I replace the toner cartridge? I found that red light is flashing( the lower light, totally there are 2 lights: upper one is green now). I don't understand what does it mean.
It mean when your toner is near empty,then red light flashing.tow light is fixed or red mean toner cartridge is empty.must be replace toner cartridge.You buy a new cartridge and put in your printer then printer is OK.
you can also get better idea please read printer user guide.
Mar 04, 2010 | Samsung ML-2240 Laser Printer
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
It doesnt print anything. the status light is red. i dont know whats wrong
A red Status light means 'paper jam'. A red light corresponding to one or more of the toner cartridges means empty cartridge. A flashing red light corresponding to one or more toner cartridges means low toner.
Aug 27, 2009 | Samsung CLP 300 Laser Printer
New yellow toner not fitting properly
try to install the cartridge again and see if it can print.or u can reinstall the printer drivers. if the problem still persists then visit below mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Jun 18, 2009 | Samsung CLP 300 Laser Printer
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
Sharp AR-M205 Copier Logo
166 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
