Question about Visioneer OneTouch 7300 Flatbed Scanner
Lines on scans
Hi my scanner has dark lines appearing on the things that i scan, any ideas if there is a way to fix this?
SOURCE: my scanner does not scan properly
time for a new scanner. these are cheap units and sounds like your lamp is going.
Posted on Feb 25, 2008
SOURCE: Horizontal line appears in scanned document
open the scanner and remove the clips, move the lense up and clean it. it is very easy to clean.
Posted on Mar 10, 2008
  • 1847 Answers
SOURCE: Visioneer 9000 Scanner Unlocked ????
  1. Toggle the lock switch on the scanner leaving the switch in the unlocked (open padlock) position.
Posted on May 28, 2008
SOURCE: Visioneer Strobe XP 100 - Vertical lines on photos
I lost my software Driver of Flatbed scanner D1250u2f. So, I want to download a new for my scanner. Where Can I get it; can you help for getting it.
Posted on Feb 08, 2009
  • 70 Answers
SOURCE: My scanner scans black Does not scan document.
Does the scanning light come on? The light may be burned out. Also Try cleaning the scanning tip.
Posted on Jul 17, 2010
SOURCE: How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
Posted on Nov 29, 2010
0 characters
1 Points
I have a big black line down the middle of my scans
If dirt sticks to the scan module, it will be scanned continuously and appear as a line in the output. Clean the glass with Isopropyl Alcohol. Dont use any other solvent.
S. Mohan, India
Mar 12, 2013 | Canon DR-5010C Scanner
Re. HP ScanJet 3970 Flatbed Scanner Horizontal lines.\r\n When I scan, I get light coloured lines approx 2mm apart across the complete scan, which show up primarily on the dark colours. Different...
Hi! I had a same issue with another HP Scanner model. I was not able to repair, so I ask my company to buy a new one. I know that it can be repaired as ething can, but as I undertand this issue occur as the head of the reader is not scrolling in the glass as expected and it can be for differnt reasons or power supply is not work properly.
Have more success,
Nov 19, 2010 | HP ScanJet 3970 Flatbed USB 2.0 Color...
My HP scanner stopped working. THe light appears
Not worth fixing. The bulb is wearing out and you can't buy them.
Dec 20, 2009 | HP Scanjet 4570cxi Flatbed Scanner
Line appears on all scanned documents. Scaning window & rollers have been cleaned.
Do the lines appear in the same location on all images? Please clean the glass with isopropyl alcohol.IF the lines are crisp and sharp at the edges on all levels of contrast, then it is module problem. If it varies depending upon the contrast chosen and is also with jaggered edges, it is dust stuck on the glass. Dont use solvents.
S. Mohan, Chennai, India
Jun 02, 2009 | Canon Scanners
Color distortion with HP 2300 scanner
Hp scanner 2300c
while scanning a blue or red line appears on scanned imajes
Mar 17, 2009 | HP ScanJet 2300C Flatbed Scanner
A Dark Vertical line appears 1 inch into the left side of scan
Most Mustek scanners have a black inside cover on the lid, this can give a black line down the side of the job.
ether cover the inside of the lid with white paper or place a bigger sheet on top of the sheet to be scanned!
Jan 24, 2009 | Mustek A3 USB Flatbed Scanner
Scanned image appears to have an exposure problem
Are you using the software from HP? It sucks. Use the one provided my your operating system works great. Go your Control Panel, Printer and other Hardwares and click Scanners, make a shortcut to your task or start menu and Scan Away!!!!
Jan 10, 2009 | HP ScanJet 5300C Flatbed Scanner
Scans slides too dark.
maybe the slides are too dark, in other words, the pictures you took didn't have enough exposure therefore you it shows up dark.. You could always use photoshop or someother photo manipulation software to lighten the scan, same thing happens with my hp scanner with slide adapter, if it slides just show up dark, lightening it with software will help, unless it is unsaturated/shadows too dark, etc..
Hope this helps.
Nov 11, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Saved files appear as small dark line
For unexplainable reasons, the Software seems to set it self to a crop of 17x1 pixels. Therefore, the files are small and the pictures essentially a small line. A reset of settings to factory defaults corrects this.
Mar 13, 2008 | Nikon Super Coolscan 5000 ED Film Scanner
Random black lines on scanned slides
Normally dark lines are a speck of dirt sticking on to the glass and when scanned continuously, it appears as a line. Clean the glass thoroughly. Ensure the slides are dust free. If the lines are appearing in different locations, it means the dust gets removed while scanning. Line in the same place could be because of glass is scratched. The above is common with roller scanners.
For fat bed scanners, there will be no scratch on the glass. It must be from the slides/documents
Feb 20, 2008 | Braun MULTIMAG SlideScan 4000
Visioneer OneTouch 7300 Flatbed Scanner Logo
Top Visioneer Scanners Experts
Mohan Sriraman
Mohan Sriraman
Sanath Kumar V
Are you a Visioneer Scanner Expert? Answer questions, earn points and help others
