Question about Olympus EVOLT E-410 Digital Camera
How do I eliminate unnecessary pre-flashes of my flash
I am getting a lot of pre flashes before picture is taken. How can I adjust my E-410 Olympus slr camera so this does not happen.
  • plarge626 Dec 23, 2008
    I tried restarting by removing my battery and storage device, but I am still getting a lot of pre flashes.
    Guru:
  • 449 Answers
Set your function button to pre flash. Push it, the pre flash will fire to meter the lights, it will also set off your strobes. Now it will hold the settings for you, no more pre flash. Your flash will fire normally now. If you have to adjust, push the function button again to cancel
Disabling the FL-40 Pre Flash
It's a fact of life that the E-10 and most other digital cameras (in all price ranges) use a low power flash pulse to set the exposure of the main flash, which follows a few milliseconds later. Many people can't tell that two flash pulses occurred. . . some can, and some blink. In fact, some people blink just fast enough that their eyes are partially or completely closed when the actual image is captured.
This "pre flash", as it is frequently called, is also the reason that you can't use a conventional remote flash trigger on a second strobe. The pre flash sets off the remote strobe just milliseconds before the main flash goes off. Since the duration of the flash is typically less than one millisecond, and the time between the two flash pulses is in the 10s of milliseconds, the picture get no benefit from the remote strobe unit. But back to people and blinking eyes.
I've taken thousands of pictures of people with the E-10 and FL-40 and most of the time I get open eyes. I have also had a few of those closed-eye shots that I really hated to lose. So I began playing with the FL-40 to see if there was a work-around - some way to eliminate the pre flash and still allow the FL-40 to operate automatically. As you have guessed by now, there is. Olympus mentions in the manual that the FL-40 can be used in automatic mode with non-Olympus cameras. It's just like using a Vivitar or Metz flash, the strobe does all the work, and the camera uses fixed settings. There is only one flash pulse - no pre flash.
All the necessary controls
Flash sensor allows FL-40 to work alone.
The FL-40 is completely capable of operating as a stand-alone automatic flash. All you need to do is set the ISO and f-stop to match the camera. The sensor on the front measures the flash instead of getting the information from the E-10. The problem is this. When you place the FL-40 on the E-10, they "know" they are connected and insist on operating in Through The Lens (TTL) flash mode. Olympus provided no way to disable this feature, but it sure seems like they could. So the trick is to just keep the flash and camera from talking to one another, and it's easy to do.
To make the FL-40 function as a stand along automatic flash, just deprive it of the control lines in the E-10 hot shoe. A piece of paper or plastic will do it. The contacts in the hot shoe that allow the FL-40 and E-10 to communicate are in front of the one that is used to set off the flash. All you need to do is insulate the camera contacts from the flash contacts and you're in business. I used a piece of paper with Scotch tape on both sides to add a little durability. It could just as easily have been a piece of thin plastic. Just don't use a Post-it-Note because after awhile the glue could cause conhow do I eliminate unnecessary pre-flashes of my f - inuse_300.jpgems when you want to operate in TTL mode.
Lock the FL-40 in place as usual. The paper or plastic insert will block the TTL signals from the flash. A sample insert is available at the bottom of this page. I just blocked the contacts and locked down the FL-40. There is more than enough pressure to hold the paper in place. happy holidays
Posted on Dec 23, 2008
  • 365 Answers
The flash control can be set to the needed level and thus the problem can be solved.thank you
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, I was made to understand that this is a feature. However, you may want to try and check the Flash control mode TTL Auto (TTL pre-flash mode), Auto, Manual and disable as per your requirement.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 22, 2008
    Master:
  • 763 Answers
Try resetting by removing the battery and storage device.
thank you for using fixya
CHARCOIS
  • Charris Suaybaguio
    Charris Suaybaguio Dec 23, 2008
    if this all suggestions doesnt help then it should send to repair service. to fix the problem
    CHARCOIS
How do i turn flash off on my olympus stylus 410 camera
Press cursor-right repeatedly to cycle through the various flash modes. The one you want is the lightning bolt in a circle with a slash through it. For full details see the "Using the flash" section in the reference manual (beginning on page 72 in my copy). If you need a manual you may download a copy from here.
Dec 16, 2012 | Olympus Stylus 410 / ? 410 Digital Camera
Telescoping lens opens but the view finder continues to flash an orange light and I can not push the button and take a picture. I have ordered a new battery to see if that helps because the camera is used...
Before trying the new battery, try cleaning the battery compartment contacts with a cotton swab dampened, not drenched, in rubbing alcohol. Blow dry the compartment and then try the new battery. Thanks, Dana
Jan 06, 2010 | Olympus Stylus 410 / ? 410 Digital Camera
Olympus Stylus 410 digital flash not working
I have the exact same problem. is it just something that happens with this specific camera ? can someone please help. i spent alot on this camera and now its not working. i've had it for 4 years ?
Aug 10, 2009 | Olympus Stylus 410 / ? 410 Digital Camera
Flash Does not work. Can only take pictures in flash-off mode
The problem you are describing is a problem with the flash charging indicator switch inside the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 30, 2009 | Olympus Stylus 410 / ? 410 Digital Camera
I am getting a lot pre-flashes before take the photo
In your manual look up page 49 AF illuminator change the setting to off and then you rprblem will go away I have had this camera for ages and couldn't figure heaps out this was so easy to fix yet so hard to find the answer. I am also finding that the photo that I see throught the lense is good and nice colour until I put the shuter button down and the photo changes colour then are you having the same problem?
Dec 23, 2008 | Olympus EVOLT E-410 Digital Camera
Olympus evolt 410 flash
I have the Olympus e-410 and I cant get the pictures to upload to my PC. I have connected it and have gone into easy print and normally that works. I have even had to turn the camera off and on a few times and then it will kick in but it wont do any of that this time. I cant find the manual and it was my husbands camera before we got married and he only upload once before that. HELP!
Jan 03, 2008 | Olympus EVOLT E-410 Digital Camera
Flash Not Working/Picture Not Taking Unless Flash Turned Off
well u can´t do much, it needs to have the board to be replaced. normally the repair centre just repair it, and if it is under warranty they will do it for free, probably the store was the one saying that u drop it to get some money.
Feb 22, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
OLYMPUS 410
It is something that seems to be a problem with the Stylus 410s. Olympus will not repair them unless they are under warrenty, I've tried. My best advice, and what I am in the midst of myself (I have 2 of these with the same problem) is to file with the BBB. Perhaps if enough complaints come through, they will begin to fix the stylus 410 defect as they should. Good luck. =)
Oct 13, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Will not take picture
This has happened with 2 of our Stylus 410s. It has to do with the flash not working. If you turn off the flash, the picture will take. I am trying to figure out how to fix the flash portion myself...=)
Sep 27, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Olympus EVOLT E-410 Digital Camera Logo
96 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
