Question about Mitsubishi VS-45605 50" Rear Projection Television
Flickering t.v. when i turn on my t.v. it flickers for acouple hours before the screen clears up...
    President:
  • 3,130 Answers
There are bad capacitors in the power supplky and or the PIP board. if you have no solid state repair experience, call in a pro to assist you in this repair. Good Luck
Posted on Apr 08, 2007
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
When I turn my computer on the monitor constantly flickers on and off. After about an hour this stops the the screen goes black about five times, but after that it works fine?
You need to download the latest graphices drivers and get the update for the BIOS.
If the screen flickers in the BIOS screen as well that means the sys has to be repaired for the screen.
Feb 06, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Lp70 flickers and color wheel chirps at the same time. It's worse with more white in the image. Colored screen shots or dark movies have limited flickering. No issues prior to hookup to computer (Infocus...
it's chirping because it's trying to keep in sync with the dmd chip. for the refresh rate, go into the menu and first reset the settings to factory default. if this doesn't clear it up, try matching the signal.
Jun 09, 2009 | InFocus LP70+ Multimedia Projector
My screen looks like the tracking off. It wount stop flickering
Some electolytics on a small regulator IC are going bad. Take it to a shop.
Apr 30, 2009 | Mitsubishi VS-60707 60" Rear Projection...
The screen flickers into hour-glass figure.
It's the tube going out. You need to replace it. If you want to stay with CRT monitors, you should be able to pickup a used one for around $10.00 on Craigslist.
http://www.craigslist.org/about/sites
Nov 24, 2008 | E-Machines eView 17f3 17" Flat CRT Monitor
Picture Flickers
there is a surface mount 9v regulator location # IC2925 i think. part # BA09FP that part is mostly likely the problem. it is located on the board right behind the video inputs. on the bottom right corner(looking at from back)
Feb 21, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Screen will flicker for 3 to 4 hours then come in clear
Wait, let me guess: up until now, it would flicker for a few minutes, which you could tolerate, but now it's gone to far, am I right? Rhetorical question, you don't need to answer. I have this exact model myself, and had this problem. It's the main capacitors. Several, if not all 21, are shot, and need to be replaced. Any good shop should be able to replace them all for under $400 if you can't do it yourself.
Nov 02, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
