Question about Gigabyte GA-7VTXH Motherboard
Makes an grrr sound for a second(drag sound) when playing music
It also sounds like in windows when opening up folders you get that sound (intermittend). I have read a forum before and fixed it but cant remember how. It was some where in the registry (deleted some files) Can't remember...
    Problem Solver:
  • 12 Answers
Try using scanreg in the windows command prompt
Posted on Dec 22, 2008
I cant put music on my mp3 player? how do i do it?
Normally, you wait for the autorun/play to open a folder to view or put your files into.
Open windows explorer to your music library. drag and drop to the first folder,
that autoplay opens, from the second folder, your music library.
It its supposed to be that simple.
Please rate this answer.
Aug 31, 2011 | RCA TH1101 MP3 Player
I sync it, but when it is completed there is no music on my mp3 player, what could be the problem?
dont go the music folder go to the files folder they should be there.n you have to move them to the audio folder! hook your player to the computer open it in the my computer window then open the music folder the songs should be there then open a second my computer window and grap the songs from the first window drag them to the folder that says audio in the second window and drop. I found it much easier to save the songs to my document folder then just drag and drop them into the audio folder
Jun 29, 2010 | Sharper Image 1612911 MP3 Player
Need help puting music on ACC file
To convert music to AAC files you have to download itunes, if you dont allready have it, when you have done that play the songs you want to convert one by one in itunes, has you play them right click on the song, then right click create AAC version, when the track as been converted you will hear a bell sound, then right click again and click show in windows explorer, the songs you convert will go into a windows folder, the best way to do it is when the song goes into the folder drop and drag them onto your sd card, then as the songs go into the folder do the same, you can put them in a music file on your sd card to make it easy to open when in your dsi, when you have all the songs on your sd card, pop it into your dsi, then open the music folder and play your songs, hope this helps you cheers Roger M.
Jan 19, 2010 | Nintendo DSi Black Console
Lg ks360, cant get music playing off memory card
Connect USB lead, open "My Computer" access the memory card on "Removable disk (G)" - This will list the files in the "Music" folder. Open up my computer again & drag the files from the "Music" folder to the "Sounds" folder. When you then disconnect the USB the files will be in the "Sounds" section of the Media Album on the phone and can be played back. Hope this is of some use.
Jun 09, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
I don't have any instructions on how to get music on my mp3 playe
You will have to drag music onto it from your hard drive that you either bought, downloaded, or converted to MP3 format.
  1. Plug in the MP3 player via USB to your computer
  2. Choose to Open Folder and view files
  3. Open a new folder and go to where you have MP3 music
  4. Drag the music you want on your mp3 player from your music library
NOTE: Make sure to use the function "Safely Remove Hardware" on Windows computers, before unplugging the drive otherwise you can cause the player not to work correctly.
Mar 24, 2009 | Element Electronics Zr-Element Digital...
I don't know how to download music to my Pandigital frame.
Must be Mp3 format.Music files copied directly from a CD will not play on your frame. All music needs to be converted to a MP3 format, and then copied to your frame. This is really a simple issue of drop and drag after that. Open 2 windows explorer windows. You will find windows explorer in your start menu. Find the removable drive maked pandigital. Locate the audio folder, and click open.
In the second explorer window locate your MP3 files. Drag desired files to the first explorer window.
Feb 14, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
I copy songs into my mp3 audio player
check the type of file format, it will say .wma, mp3, mp4, avi, some players can only play .wma, or .mp3 i pods use mp4, or something, if not an ipod than convert the music to .mp3 or .wma and re load into the mp3 player. are you using a sansa? in the picture above, if so then you can just click the mouse on the the song hold it and drag and drop the song into the player folder. here try this hook your player to your pc, open up my computer, select the drive that idetifies your player, double click, find a file that says audio or music open it that is the directory folder for the music to play from in your player, now keep that open, and open up the folder where you have stored the music in you pc and select whatever song you want, click and hold the mouse button on the song drag the song over to the player folder and let go of the mouse button within seconds it should appear, but like I said before make sure .wma or .mp3 is at the end of the song title, like this
All along the watchtower.wma or Sweet emotion.mp3 , it also helps to adjust the windows smaller to fit them both on the screen that way you can just drag and drop faster. I hope thiis helps.
Feb 06, 2009 | Coby MP-C7085 MP3 Player
Can i make a song a ring tone on the g1 phone
download the free app ringdroid in the app market.connect g1 to computer and mount .drag music into music folder.then open rigdroid.the music you dragged into folder should be here.cut the waveform however you want then save. now you can go to settings and under sound and display you can assign your newly made ring tone to your default tone.
Nov 30, 2008 | HTC G1
I need to put nusic on my mp3 but i am technologically retarded.
You can manually drag and drop the music onto the device thru My Computer. Just open up the folder containing your music, probably My Music. Open a second window My Computer>Device Name. Inside you will see a music folder, just drag the music from your My Music folder into the Music folder and viola, youre done. Best of Luck.
Sep 18, 2007 | SanDisk Sansa m240 MP3 Player
Gigabyte GA-7VTXH Motherboard Logo
274 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
