Question about Harman Kardon Go + Play Portable Speaker System for Apple iPod - Matte Black
Harman Kardon go + play problem
My Harman Kardon go + play keeps turning off and on by itself. Please help.
Thanx.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 22, 2008
  • 3 Answers
Often the advanced energy management circuit cuts out when on battery power and no music is present.
1. Remove batteries run on AC
2. does unit still work?
3. If so plug in Ipod normally, turn HK unit volume down then the ipod volume way up.
4 if problem not solved try using 1/8 inch aux. jack, high volume on IPOD low volume on HK.
IN general contol the volume from the HK unit. leave the ipod loud.
Posted on Sep 23, 2010
My Harman Kardon is AVR 151. It's not on. the power led is blinking. Sometimes it work correctly.i don't know what to do. please help!!!
Normally its a power supply that does that its protecting itself from further damage you will have to check the transformer or power supply in the unit normally it would be blown capacitor s
Sep 03, 2016 | Harmon Kardon Harman Kardon AVR1510...
HARMAN KARDON ESQUIRE , TURNS OFF INSTANT WHEN LIGHTS , NO PLAY SOUND.
Lifetime Support baby. Hit em up bruvva.
http://www.harmankardon.com/content?ContentID=why-buy-direct
Jan 05, 2016 | Harman Kardon Audio Players & Recorders
I have a harman kardon avr110 that turns off by itself seconds after tuning it on.
could this be the(now) famous harmon kardon self checking circuitry sensing a fault in something ? the place to look 1st is the speaker wiring !!
Oct 20, 2015 | Harman Kardon Audio Players & Recorders
My Harman Kardon go play II will stop working just after just a few months.
If you bought this you this new, take it right back to the place of purchase, you still must have warranty and I would use it asp other wise you will be stuck with a unit that will get worse. This is clearly a manufacture defect.
Mar 30, 2012 | Harman Kardon Go + Play Portable Speaker...
Harman kardon go and play don't have video out port
If I understand you correctly the Harman Kardon does not supply the output video and usb ports. Since this is a go and play they pobably felt it was not needed. to impliment these changes would require a complete design change.
Mar 28, 2012 | Harman Kardon Go + Play Portable Speaker...
Harman Kardon AVR7550 turns itself off.
check to see if there is a reset switch inside on transformer bd. could be dirty. clean with contact cleaner.
Nov 26, 2011 | Harman Kardon Audio Players & Recorders
DVD 30 turns off when I put a disc in and it reads it.
I understood your problem...Harman Kardon BDP1 BluRay Player generally it cause due to lens problem and data processor it may be creates a problem.
you have one option to use lens cleaner CD which removes dust from the lens it may be helpful to you.
Thank you for giving me opportunity to solve your problem.
please give me your Ratings!!
Jun 20, 2011 | Harman Kardon BDP1 BluRay Player
MY HARMAN KARDON GPS-500 WILL NOT CHARGER
If purchased in last 2 years will still be under warranty Harman Kardon support recommends Return to retailer for return to harman kardon for repairs.Seems that the battery and charger units for the gps500 models are not that reliable and as such may fail as fit for purpose.Contact retailer for returns policies in regards of warranty of units
Sep 10, 2010 | Harman Multimedia Harman Kardon Guide+Play...
My harman kardon soundsticks base light flickers, no sound
Ok this needs careful observation to determine this type of problem
Please unplug these speakers and plug it into an mp3 player and write back to me if the speakers work ok? I'll tell you more from there
Mar 15, 2010 | Harman Kardon SoundSticks II Computer...
Harman Kardon Go + Play Portable Speaker System for Apple iPod - Matte Black Logo
1,133 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
