Question about Yamaha HTR-5830 Receiver
It keeps turning off
I accidently touched the wires together while it was on and immediatly the unit shut itself off.I plugged the wires back in the speaker and turned it on but shut itself off after 5 sec. I unplugged everything and plugged just the power cord back and the problem still persists. Any help would be greatly appreciated.
    President:
  • 3,130 Answers
The audio output ICs or transistors are blown. Solid state elctronics are not very forgiving when they are shorted. it takes one tiny instantance and the componets will fry. sorry to be the bearer of bad news but you will need to have this unit serviced or replaced, And never ever work on any type of electronics with the power still on. Good Luck
Posted on Apr 08, 2007
My unit flashes "fan check" and keeps shutting itself off
try to plug it off then look at back and try to blow to your fun or try to spin it with something a bit and plug in it back it should work and do not keep your fun to close to wall or cables
Mar 30, 2014 | Samsung Televison & Video
My performa dryer is leaving burn marks on clothes. The marks (pattern) is from the covered opening on the back of the dryer. Any idea what could cause this or how to fix it?
You have a bad sensor that is not sensing when to turn the heat off, it just heats full on the whole time, you can check sensor with the power off and a meter on continuity, the sensors are located on the heating tube that the coils are inside. the sensors should have shut your dryer down but maybe your sensor is stuck closed with would make it work and not tell the dryer when to turn off heat, or your wires are touching eachother where the sensor is located, so you accidently or defectively the wires are connected and not running through the sensor
check the wires and replace the sensors. there are a few sensors on my dryer, they are small devices that sit on the exhaust tube and the heating coil can, simply use your probes to check for continuity on the two lead wires to the sensor, and make sure the wires are seperated and not touching eachother where they plug in to the sensor, one may have gotten bent over and now you have a jumper. same as if you pull the wires off the sensor and touch them together. I have a bad sensor and touched my wires together and now my dryer works, but is dangerous, and needs monitored until you get a new sensor in place and hook up correctly
Jan 01, 2013 | Dryers
My seat ibiza radio keeps turning itself on and running the battery down
Simple solution for anyone! Had the same problem with radio turning itself on in my Seat Ibiza Stella 1.4 2000. Here's what you do..
. Remove front panel
. Disconnect tape player and open it
. Clean the mother board paths(bottom side) with some chemical liquid not to strong(i used sticker remover) from black dirt. You can scratch between paths with a needle for better effect.
. Put all back together
. Problem solved.
It was driving me mad but now it's working when I want it to :)
Jan 08, 2012 | Cars & Trucks
Heat rising furanceon constantly
Hi, There are so many safety controls on most heaters that are designed to shut down the heater if something like this were to happen. I have only seen this happen once in 33 years where the residents were gone shopping, and the heater did not shut off. The plants were all dead as were there pet bird. I believe what is happening, if the thermostat is good, you have a wire in the thermostat cable touching together somewhere. The Red wire to the White which will cause the unit to run all the time. I would first turn off the power to heater and pull the cover and the front of the stat off to excess the wires. Take loose the red wire and it should shut off after a time delay. If it does shut off then the thermostat is faulty. If it continues to run and heat, look closely at the wires at the stat to make sure they are not touching together some where. Check at the heater also where the stat wires come in to see if they are touching somewhere. If you can't see anything, take the red wire off at the heater where it terminates to unit and this should stop the unit. If it does you will know that the wiring from the heater to the stat is touching in the wall somewhere. We use an ohm meter to check continuity on the wires to see which ones are touching. If the heater continues to run with the wire disconnected from it, depending on the age of the unit and if it has a circuit board on it, it would have a shorted connection from hot to w or heat. I would say you have a faulty stat and or wiring touching somewhere calling for heat to be on all the time. This is all it can be. Do the checks I have said and keep me posted on how you are doing. I will wait to hear back from you.
Good Luck,
Shastalaker7
Dec 11, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
My water heater is buzzing then shutting off. (no hot water)
the power interrupt switch is detecting a short in one of the heating coils.  With the power off remove the side cover pull out the insulation and disconnect the wire to one of the heating elements.  Make sure it isn't touching anything and turn the power back on and see if the problem continues.  If it does reconnect the wire and do the same to the other heating element.  Be careful.  If you feel uncomfortable doing this call an electrician.
Mar 30, 2009 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
It shuts off right after I turn it on.
Hi....
It's usually a component failure in the power amp section.
There are good tech shops in Cailfornia
Mar 24, 2009 | Denon AVR-1508 Receiver
Toshiba home theater SD-KT50SU shuts off "PROTECTION"
Ok what this means is that some wires are touching in the back of unit causing a short (your system is protecting itself) look for wires touching and make sure its hooked up right
This should fix ya!
Dec 13, 2008 | Sharp XLDV60H Shelf System
I touched two speaker wires together and amp will not respond
That is a very nice amp . Try not to touch (short) those wires together. But yes, the amp has protection and is shutting off to protect it.
Nov 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Yamaha HTR-5830 Receiver Logo
177 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
