Laptop works but after logging off at end of day, user comes in next morning and his d630 is locked up and only way he can get it unlock is to shut down laptop
  • 2 more comments
  • lynn_longdon Dec 22, 2008
    The user logs onto the network via CAC Card. The user logs off at end of day. When he comes in the morning, it is locked. He didn't say anything about a password.
    I am on my way back over to Bldg 485 to check his standby, sleep, or power saving mode settings and I'll provide more information then.
    Lynn Longdon
  • Dan rogers
    Dan rogers May 11, 2010
    that would be the same password he uses to log on in the morning. So in case i mussunderstood is it locked up like it won't do anything or the password thing?
  • ryantmer May 11, 2010
    The laptop is probably set to ask for the password on resume. You can turn this off, but it would be easier for the user just to know the password...
  • Dan rogers
    is sleep mode or power saving enabled?
    Master:
  • 413 Answers
If it does have power stuff enabled i have had some very strange problems because of this so that is usually one of the firs things i check. Of course any network activitiy that tries to connect to that computer when they are logged off might have something to do with this too.
Posted on Dec 22, 2008
I hit lock instead of log off last time I was in my account
Try to start in safe mode - press F8 as the laptop is starting
Mar 01, 2014 | HP Compaq Presario CQ60-249US Notebook
Gateway login
What sort of problem at log in >>?????
Forgot password ?
A "setup password" is a password that you must enter to log into a user account on your Gateway laptop.
This can be beneficial if you have a number of people using the same computer and don't want just anyone having access to your personal files.
But if you are the sole user of your Gateway laptop, then it can be more of a hindrance.
As all Gateway laptop computers run a version of the Windows operating system, you can remove the setup password by accessing the Windows Control Panel.
Click on the "Start" menu.
Select the option that reads "Control Panel." If you're running Windows Vista or Windows 7, this will have its own listing in the "Start" menu.
If you're running Windows 95, Windows 98, Windows ME or Windows XP, this will be found under the "Settings" sub menu.
Double click on the icon that reads "User Accounts."
Click on the name of the account that has a setup password that you want to remove.
Click on the "Remove my Password" option.
Enter your current password into the appropriately labeled box.
Click the "Remove Password" option.
Click "OK" to save your changes and exit the "User Accounts" utility.
The setup password will have been removed from your account, and you will be no longer prompted to enter it when you boot up your computer.
Unlock a Gateway Computer
Getting locked out of your Gateway computer can be frustrating, especially when you have school or work deadlines.
You can get locked out of your Gateway computer in cases where a password protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Gateway computers come with Microsoft Windows XP and 2000, including the professional versions of both. Knowing how to unlock your a Gateway computer can save you time and irritation.
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer." Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear. Log on as usual. Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool.
This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer.
Note the dialog box that comes up called System Shutdown.
Wait for the shutdown timer to run out and see the Welcome to Windows box displayed on the screen.
Press "Ctrl," "Alt" and "Delete," which unlocks the computer.
Log onto your Gateway computer normally.
Method 3: Backup, Modify and Restore the Registry
Click "Start" and "Run," then type in the command below in the field box exactly as printed:
%SystemRoot%\system32\restore\rstrui.exe
Click "Create a Restore Point," then click "Next" on the Welcome to System Restore page that appears.
Type any name for the restore point, then click "Create" on the Create a Restore Point page. Click "Close" after creating the restore point.
Perform this procedure before you make changes to the registry, just in case you make an error; otherwise, incorrect registry changes could create serious problems with your computer.
Click "Yes" if you receive a prompt to turn on System Restore at this point.
Clear the "Turn Off System Restore" check box by clicking on it, then click "OK," and repeat.
Click "Start," then type "regedt32.exe" (without the quotes) in search field box to modify the registry and unlock the computer. Press the "Enter" key on your keyboard.
Locate the scrnsave.exe value under the registry key below:
HKEY_USERS\.Default\Control Panel\Desktop
Click "String" on the Edit menu, type "logon.scr" (without the quotes), then click "OK."
Look for the ScreenSaverIsSecure value, then click "String" on the Edit menu, type "0," then click "OK."
Quit the Registry Editor
Click "Start" and "Run," then type the command below exactly as printed to restore the registry, then click "OK":
%SystemRoot%\System32\Restore\Rstrui.exe
Click "Restore My Computer to an Earlier Time" on the Welcome to System Restore page, then click "Next."
Note your computer may already be selected to restore to an earlier time--in this case, just click "Next."
Click the system checkpoint on the Select a Restore Point page. Click "Guided Help (Registry Backup)," then click "Next" on the "On This List Select the Restore Point" area.
Click "OK" if you see a System Restore message listing all the configuration changes it will make. Click "Next" when you come to the Confirm Restore Point Selection page.
System Restore will now restore the Windows XP configuration you had at an earlier time, and then it will restart your Gateway computer.
Log onto your computer as usual, and then click "OK" when you see the System Restore Confirmation page.
Nov 26, 2013 | Computers & Internet
2 days ago spilled wine on keypad of dell Latitude D630. Cleaned the as best as possible, next day the "Back Space" key would not work. Removed Key pad and cleaned with alcohol. After re installing the key...
that is a bummer for everything went into the mother board and now it is fried. find another computer like that one and change the hard drive and put it in the other one
May 27, 2017 | Dell Latitude D 630 D 640 D 520...
What is the fastest way to get into your sign in box?
I go to sign in and log on. I dont log out at the end of the day and let my laptop/pc hibernet. Next morning go back and refresh the screen and I am in the emails.
This works for me but I don't know whether it is right or wrong.
Aug 20, 2013 | Computers & Internet
I think that any persons here can´t erease the master password on dell d630 its too much for your´s
The master password for the Dell d630 BIOS can be erased. The password for Windows has to be dealt with by the administrator of windows.
Jul 20, 2009 | Dell Latitude D510 Notebook
I cant unlock my apple laptop how do i unlock it'
Last month , i lost my windows administrator password. I solved my problem with the help of
windows password key 8.0. It worked perfectly to reset any local user account to a blank
password. Just an easy to use bootable CD/DVD . It can also be used on a USB Flash Drive. You
can download it from: http://www.lostwindowspassword.com/.
Jun 22, 2009 | Apple aluminum 13-inch MacBook laptop-...
Someone got on my laptop and did not log out. how do I let another guest sign on to get their email?
If the laptop is locked by that user, just power down the laptop by holding down the power button for 6 seconds, it will shut down.
If not, just log that user off and have someone else login.
You could also switch users instead of log off.
Mar 18, 2009 | Dell Inspiron 1525 Notebook
Need system unlock code for dell latitude
So I bought a Latitude D620 and I bet u heard this a million times already it came with the famous This system #xxxxxxx-xxxx, is protected by a password authentication system. Any help from the gods of this site would be appreciated. below are the numbers needed i believe,
CHZ0P2J Service tag
272-081-320-75 Express code
This system #CHZ0P2J-595B is protected by a password authentication system.
Any help would really be appreciated. thanks in advanced.
Nov 04, 2007 | Dell Latitude C400 Notebook
Computers & Internet Logo
23 people viewed this question
Alun Cox
k24674
