Question about Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera
Won´t power on
Hi, I´m currently travelling in Bolivia and in the last few days have gone from humid lowlands to freezing highlands. I´ve found after a particularly wet evening that the camera started playing up. First, the LCD fades out, then on turning the camera off, the camera won´t power back on. I took the battery out and let the camera dry out (if it needed to) and after a day it started working again. But after a second day of rain the same problem has occurred, only this time it won´t power on at all. Any suggestions are welcome, as my camera is invaluable over here. Many thanks.
  • Jane Mahony Apr 21, 2007
    Problem continued....
    After a full week of the camera refusing to power on, it is once again working, but I am concerned that this problem will re-occur. Is it possible that it was the varying weather conditions or is there a more inherent problem.
    Once again, thanks for any help provided.
  • 641 Answers
Thanks for the information.
Posted on Aug 10, 2007
When and how low pressure and high pressure cell are formed
If you are about weather pressure, then on the site Studydaddy.com I found this information, there's a lot more on this subject and not only. Come and read)
Answer:
In the tropics, the sun's rays fall almost flat on the earth's surface. Heated air rushes upwards, and an area of low atmospheric pressure forms at the surface, where there is a calm. There cooler air masses flow, creating at times only weak changeable winds. These movements of air masses determine the weather in the tropics. There, in the lowlands, the greenhouse climate dominates - it is hot and humid. Since at noon the sun is almost at the zenith, the heat reaches 30 ° and above. At night, the air is very little cooled, because there is high humidity. Early in the morning it's slightly easier to breathe, but soon there will be powerful cumulus clouds in the sky, often falling down in the downpour, which sometimes lasts all night.
North and south of this belt, in the "horse latitudes", the cooled air descends to the surface, and there are regions with constant high pressure (anticyclone). The descending air masses in the form of a large spiral rotate in the Northern Hemisphere clockwise, and in the Southern hemisphere rotate against it. In these latitudes, clear windless weather is often established, in the daytime it is warm, at night it is cool. Other areas of anticyclones appear at the poles.
Apr 07, 2018 | Homework
Can you give me facts about gorillas
They are social animals. The silverback is the chief. Females nurse their young much like humans do.
Apr 26, 2014 | Winter Sports
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
My laptop won't turn on for two days (wifi light flashes on for three seconds but nothing else turns on, no hardrive or fan) and then starts again after two days and works for two more days just f
There must be a incompatability in the power supply when using the 220volts, the laptops will with stand a fair amount of humidity so long it is kept cool.
May 18, 2012 | Toshiba Portege R700-S1310 13.3 inch...
Olevia 537-b11, blue light won't come, even when power cord is replaced. Please help!!!!
Since you've already replaced the power cord and still the led light won't came on, this is an indication that the power supply board of your unit is dead. If it is not under warranty period(if so, avail it because the manufacturer will fix it for free) open the back cover and check the continuity of the fuse using the multimeter, if you found it open replaced it with the same current(ampere) ratings and then try to turn on the TV. If the replacement fuse blew again, this is an indication of more serious problem on that board. If the replacement fuse didn't resolve the issue, other parts on that board gone to malfunction as well. If this is the case, I would advice you to replaced the entire board for your convenient. The cost will almost the same rather than troubleshoot it. Check the actual part no of your board and check this LINK.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Sep 09, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Need some advise, no problem starting the car CLK (02) but the dashboard warning lights ie handbrake, engine, abs etc won't switch itself off. The next day start the car again and it's gone!...
All those warnings are controlled by the computer, so it might be a computer glich. But most likely it was hot in the car and maybe even humid in it that caused an electrical component not to work. Then when you started it up the next day it was cooler or less humid. Which is an indication that something is getting weak (electrically).
Jul 28, 2011 | 2002 Mercedes-Benz CLK-Class
Just shut off the care returned 2 hours later no go got a boost went for a drive left the car running for awhile than it start to get like it was going to stall went on g=for a littlwe while than died....
Hi your problem sounds like the battery is gone and won`t take a charge. When your engine is running the alternator is supplying the electrical power to run the car ( and normally charging the
battery as well )
Even though it seems strange for the battery to go suddenly, it does happen.
How old is the bat. Most last about 5 years with normal driving ( batterys last longer if the car is used every day )
Anyway i hope i have been of some help to you.
John (south Wales UK )
Jul 05, 2011 | 1995 Honda Civic
Canon xha1 won't turn on and hdv light keeps blinking
Same Problem, same day, have you found any solution?, i stored the camera for abut 6 months following the Manual specifications, keeping the camera away from humidity, dust, even light and unmounted batteries, but it didn't turned on when i really needed it, I tried changing batteries, power source, i've already checked the lock/standby and the main dial, anyone help please!
Jun 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
1982 Honda Magna V45 2 cylinders keep cutting out
Hi, Peter_faulkn for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1986 VF700C Magna Intermittent Ignition Problems
Total Motorcycle Forums
Honda 1986 VFR 750F Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1986 VRF750F Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 02, 2010 | Honda VF 750 C Magna Motorcycles
High color alteration on video capture on Sony DCR-HC42
your right it have to repair now cause the ccd image sensor is malfunctioning already...go to the service center for replacing the sensor...
Jun 12, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera Logo
846 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
