Question about Coleman Powermate Premium Plus 6250W Portable Generator
My coleman karosene heater won't work
I have a portable karosene heater. It is the one with a small tank on the bottom with a little pomp on the side. It wont start. I put new fuel into it and it will merely ignite and go out. I don't have instruction manual and colelman website is not helpful at all.
  • 211 Answers
Hi
Change the sparkplug with the same heat range.Clean the air filter and the gas filter.Change the gas from the gas tank.Disassembly the carb and clean it.Start the engine.
best regards savumihai71
Posted on Feb 12, 2009
How to turn on the propane heater in a coleman pop up camper
Hi Robert,Make sure you have gas in the tank ,first turn on your propane tank, the knob is at the top of the tank with a small arrow showing you the way to turn it on.Then on the heater you should see a red knob with the words-pilot-on-off.Turn to pilot then light it,you may have to push the red knob in-wards at the same time as you light it to let the gas come in.Now if you see a small flame stop pushing in the red knob and let it go slowly.the small flame should stay lit, now turn the knob to the -on-position and set your thermostat. If this did not help you please have a heater repair person help you to see if you may have a problem. remember you are dealing with gas this is dangerous.
Jan 05, 2014 | 1994 Pop-up
Where is the fuel shut off valve
Powermate generators usually have a shutoff mounted to the bottom of the fuel tank. There is a knob at the bottom of the connector where the hose is attached to the fuel tank. Screwing it in (clockwise) shuts off the fuel.
Aug 30, 2012 | Coleman Powermate Portable Generator...
Kozy world propane wall heater pilot will not light
This can be caused by several things:
1. The inline gas valve running to the the heater is OFF. Turn the valve ON.
2. The gas control knob on the heater is not exactly in the PILOT position. Unless the knob bottoms
out and you feel strong pressure (other than spring pressure) pushing back at you. It's not exactly
in the PILOT Position. Once the pilot lights, hold the control knob in for 30 seconds to 60 seconds
to allow the Thermocouple to full heat.
3. The pilot is dirty and needs to be cleaned, as do the burners.*
4. The LP Gas Tank is empty or to low to maintain te proper gas pressure.
* Here is a link to a demonstration on how to properly clean the pilot & burners.
http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 23, 2011 | The Companion Group Kozy World Portable...
I BOUGHT A USED COLEMAN 10 HP GENERATOR.IT STARTED FINE THE DAY I GOT IT,OW IT WON'T START AT ALL. ICHECK THE OIL.IT'S NOT LOW.I CHECK THE OIL FILTER IT'S NOT DIRTY. WHAT'S THE DEAL?
If it hasn't been used often it probably has a sticky Needle, this is situated on top of the float in the little tank Attached to the base of the carby, take the bowl off by a bolt at the base of it, remove the float, you will them see a small pin with a point on it, that is the needle, take it out and clean it and replace
Aug 20, 2011 | Coleman Electrical Supplies
I have just purchased a little portable gas grill. Do I unscrew the Coleman Propane Fuel cannister when I am finished cooking or leave it attache? It seemed that my first tank didn't go very far.
To be safe, Yes. Be sure to turn the canister tank is turned OFF before removing it. Also, be sure that when you reattach it, that you open the gas tank valve Very, Very Slowly (Slow Motion, slow). This will prevent the regulator from getting locked up.
Hope this helped and Happy Grilling!!
Jul 19, 2011 | Coleman Grilling
I cant get my coleman powermate 5000 MAXA ER to start. i have changed the oil, refilled the gas, changed the spark plug, and tried using starter fluid. what else can i try?
It's almost certainly gummed up gas in the carburetor. Get some carb cleaner, and some spray instant start. Drain the gas from the tank and put a small amount of 50/50 carb cleaner and gas in the tank. Remove the air cleaner, open the choke, spray a little instant start into the carb and start it. It may fire just a couple of time. Keep the choke on to try to pull a bit of gas through the carb. You may have to do this a few times. Once you can tell some gas is flowing, open the choke slowly to keep it running until you use up the 50/50 mix. Then try a small amount of straight gas in the tank to be sure it works right, before you refill the tank. Make sure you use a stabilizing additive in any gas that you store for more than a month. good luck, Al K
Feb 02, 2011 | Coleman Powermate Premium Plus 6250W...
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Will not start
if it has spark and your sure of that, check for water/condensation in fuel tank,you could even have algae growing,yes (algae) in fuels and they will plug the fuel line,filter,nozzle,etc.
Feb 09, 2009 | Reddy R60A Utility Heater
What gas to buy?
used or new? if new the coleman will fit push in and turn at the same time the small fine threads have to mesh properly.
If used they may have converted it to a 20lb tank if so unscrew the adapter then hook up your little tank.
hope this helps
Feb 04, 2018 | Vortex Optics Vortex 14.5 Inch Tabletop...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
76 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
