Question about Epson AcuLaser C900 Printer
Epson c900 paper tray missing from printer but still comming up with n06018 error is this due to the paper tray missing or is it something else green and red lght flashing at the same time
  • jamal shah Apr 21, 2007
    Contacted epson they said it s the laser unit
  • Epson Master
  • 705 Answers
Yup, they are right (they usually are) this is what the service manual says: (see http://www.TheserviceManualShop.com for a manual)
Posted on May 13, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Why is my Epson WF7620 showing" cassette 1 insert correctly"
The switch inside that makesxeither an electrical connection orca mechanical one tells the printer that the paper tray is home loaded and awaiting commands is not being activated by the tray
The switch has become faulty overtime and needs,a replacement
The bit on the tray that pushes the tray loaded switch has broken off the tray is missing the switch or a wiring fault has developed
And the switch has no power so it still can't see the tray even if it is loaded thus error paper tray missing continuously is being displayed
Jul 04, 2016 | Epson WorkForce WF-7620 Wireless Color...
Printer Driver for Linux : Epson C1000
Hello
Try these links.
driverscollection.com/?...ACULASER%20C1000...Epso... - United States
support.epson.ru/upload/library.../howtoinstallprinterdriver_linux.pd
www.downloadsarea.com/Free_driver-epson-aculaser-c1000-linux/
http://www.dataentryjobs.us/67948.html
Feb 09, 2012 | Office Equipment & Supplies
When I try to print, a flashing red light comes on and the printer does not function. I cannot access the menu which gives the stus of the toners etc or instrcutions how to... so I cannot identiofy the...
check the toner ,, check paper jam and ,, paper tray ,, or any sensor issue,, don't give the print order untill you see the green signal over the printer...
Apr 27, 2010 | Epson AcuLaser C900 Printer
After a paper jam
hi
this is a common alarming message, it also occurs intimes of abrupt power interruptions.
It is true that this might end up being a technical issue, however from your explanation it is as a result of a paper jam.
fine before we get down to technical solution WE HAVE TO USE ELIMINATION METHOD IN SOLVING THIS -NOTE THAT YOU HAVE TO BE VERY CERTAIN OF YOUR FEED BACKS/ CLARIFICATION.
ELIMINATTIONS
POINT 1 - cover open
Are all the cover closed tightly and in place, Do you hear a clicking sound when u shut the cover?
POINT 2 - multiple sensor failure
caused by paper jams and the paper shatters /tares inside the printer : At such time the paper was forcefully /ignorantly pulled off the printer from either AB cover or the paper tray.
In such cases the printer will issue all sorts of error messages not limited to error 6022 to the common paper jam error.
Remedy: open cover AB, study the transfer unit (the hot part), all level sensors (things like seasaws) -- remove all loose paper parts .
better still download this PDF and Do a thorough quest
http://tech.epson.com.au/downloads/RedirectLink.asp?ProductID=alc900&Email=&DownloadID=4464
having done that ur printer should work.
POINT 3 - Low Power
Is your printer on a UPS or some sought of power devices. Remove those devices and put the printer on DIRECT power outlet.
Sorry but we gonna go technical from here :)
POINT 4: Loose addons / peripherals (elementary)
Remove the waste Tonner collector, photo conductor and the transfer unit buy opening cover A. inspect the last two items for paper traces.--- Attention photocoductor is light sensitve and should not be touched on its green surface. pay particular attention to the moving parts i.e the gears.
restore the above making sure they enter firmly. Power on your printer. It should work. if not you may try doing the same to the toner catridges.
POINT 5 : Loose Rom Module
Did it really go loose ? May be or Not. Or during the process of removing paper the printer was lifted / Tilted and some culprit (dust) fell on the ROM which is placed horizontally inside the printer.
U require a STAR screw driver. Opposite cover A , the only metallic side of your printer u will find some sticker in yellow with writings bla bla bla - dont open here. Open the protruding part on the Right, it has 5 screws.
The ROM is something that looks like a half sized credit card put in some type of Socket
Find the Rom, Blow it (simply by mouth) and Push it in NOTHING ELSE.------------ WARNING, WIPING, TOUCHING -TOUCHING,CLEANING WITH CHEMICALS ARE TOTALY PROHIBITED.
I hope this fixes your problem, i have managed to recover from such problems severally
Labatt
1.
Apr 08, 2008 | Epson AcuLaser C900 Printer
Epson Aculaser C900 - Paper Jam Notice, but no Jam?
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Jan 14, 2008 | Epson AcuLaser C900 Printer
Start up cycle continues?
This is the normal start up procedure. The green light will continue to flash until it has completed the startup/warmup rpocedure.
Oct 15, 2007 | Epson AcuLaser C900 Printer
Epson C900 print shifted down page -
OK after messing about with the drivers I got it to work. I downloaded a driver from Epson singapore and it made no difference. So, I re used the driver from Epson UK and hey presto the thing works again. Why? Good question. Maybe the people in Epson have no idea either.
So, I suggest deleting the driver rebooting the system and reinstalling it. I hope you get it working.
Oct 08, 2007 | Epson AcuLaser C900 Printer
Not printing
there is paper jam or there is the dust in some sensor
Sep 12, 2007 | Epson AcuLaser C900 Printer
Error Code 6001 ~ 6999 are simply service required errors and are very general. I would imagine that if the tray is missing the printer will produce a fault. For starters it will think it has no paper and therefore will not try to pick up paper from the tray. If the tray is opened during operation I believe the printer stops, therefore there must be a sensor for the tray - no tray means sensor is operated. Best guess - fit a tray.
Apr 07, 2007 | Epson AcuLaser C900 Printer
Epson AcuLaser C900 Printer Logo
126 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
