Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag Jetclean Super Quite Plus II Dishwasher
My dishes will not come clean. Everything seems to be working, the water comes in and sprays around etc. but the dishes continue to be dirty. I have even taken it all apart and cleaned it out -- but that did not help. Please help.
  • 2 more comments
  • robcalie10
    robcalie10 Mar 19, 2013
    My dishwasher isn't cleaning my dishes and the gel packs are not dissolving. Please help
  • djgeiger120
    djgeiger120 May 07, 2013
    im cant get any water im the dishwasher The water is on and running to the machine
  • Anonymous Mar 16, 2014
    Dishwasher continues to run. Dishes cold and wet but relatively clean. What could be the problem please?
    Hi, we have a Kenmore dishwasher 665 13743k601. It has not been getting the dishes very clean for a while and now the motor is extremely loud when I turn it on. We have taken the dishwasher apart and checked the bottom screen, rubber flap and cleaned the bottom-everything looks good. Any ideas?
    President:
  • 1,462 Answers
Open the door when working and check the spray arms are rotating. if not, the jets in the spray arms may be blocked. very fiddly to clear but doable
Posted on Apr 09, 2007
My spray arms were clogged solid. I removed them, soaked in CLR for 15 minutes, was able to poke through solid crystalline plugs in the spray holes of top and bottom spray arm with a toothpick, and rinsed out all the debris. From then on, I used CLR every two months or so, adding recommended amount at the time of the cycle it recommended on the bottle of CLR.
Posted on May 10, 2007
SOURCE:
It is just not cleaning the dishes. Runs - OK
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 24, 2011 | Maytag Jetclean II MDBH945AWS Stainless...
Have a white film all over all my dishes and silverware
Hi
Daniel
Nov 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
My Maytag Dishwasher not cleaning the dishes. Doesn't seem to have enough water pressure.
clean the screen in the water control valve that is what the water line hooks up to or it may need to be replaced
Jun 09, 2010 | Maytag MDB9600A Jetclean II Built-in...
Dishes are cloudy and have soap residue. Have cleaned upper &lower spray arm often, as good as posible (find holes plugged). water level & temp. seems normal . Water intake screen appears clean
Clean the spray arm jet holes if they are blocked. Check whether you have filled the rinse-aid dispenser.
Check whether arm turns freely when rotated by hand manually.
May 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
Dishes on the top rack not cleaning properly
Had similar problem with our Maytag dishwasher--we removed all spray and screen components to the inner case, cleaned the intake screen below the lower spray arm, repaired a split upper spray arm, and inspected everything for cracks or other distortion. All of this helped some, but finally improved things by changing from liquid detergent to a "packet" type. Our water is somewhat hard and builds deposits on the screen at the bottom. Run a no-dish cycle with a cup of white vinegar in the bottom.
Aug 07, 2009 | Maytag MDB9600A Jetclean II Built-in...
My Maytag jetclean dishwasher is not cleaning the dishes and the soap is not dispensing. I am also not sure the water is coming in? Help?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
a
Jun 10, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
My dishwasher isn't cleaning my dishes!!!
Look and see if the seals at the back of the dishwasher are worn. They may need to be replaced. The seals are easily removed and new ones replaced. If that isnt it then check to make sure the pump screen is not clogged. Remove the screws to the covers in the bottom of the dishwasher to expose the screen.
Aug 29, 2008 | Maytag 24 in. MDB8600AWS Jetclean II...
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
1,533 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
